OCT NOV DEC BS THREAD
Old Nov 24, 2022 | 05:44 PM
  #31
F10B1317's Avatar
F10B1317
Originally Posted by Cracker289
I didn't see the 67 Ford truck episode, I may have to watch that later. I saw the very first episode which was an old Mustang (68 maybe?) that he drove with the door flopping around. He also took delight in peeling out in the grass and messing up the yard where he pulled the Mustang out of, that just kind of set me wrong. I still don't "get it" - why work on it in the grass in a strangers field when you could tow it to your shop and have all the tools necessary to do a better job, not to mention having concrete floor.
I also saw the Dodge tow truck episode; now at the end of that episode he hooks the hitch up to an old Ford pickup and starts pulling it out, so the episode you mentioned must be the next one and maybe that's the truck he was about to start on?
This series on motor trend isn't his first work, he has a channel on YouTube called Vice Grip Garage that I linked to above that he's done independently for years. That truck he picked up is the '67 though it was just for show as it runs great and he gave that truck to his kid who helped him with it when he was 10 or 13.
Old Nov 24, 2022 | 06:52 PM
  #32
FuzzFace2's Avatar
FuzzFace2
John,
I did not know what shape the Barracuda was in when it was picked up other than the tire I saw in the pictures you texted.
Guess it was just the 1 tire that did not stay on the car LOL
Good you were helping as everything would be replaced if it gave any trouble other than the battery LOL
Also nice you got it running just wonder why the bolt was removed from the crank and them bolt holes?
Think Mark needs to look into a new balancer or if what he his is right.
Besides the carb rebuild and think cooling system put back together what else looks like is needed to run the motor more?
I think someone said the car has 3 on the tree and if so is the clutch rusted to the flywheel? Pretty common when they sit for a bit.
Guess the whole brake system needs to be replaced?
I have not looked at the video dose the system have a single line master?
Dave ----
Old Nov 24, 2022 | 11:12 PM
  #33
Cracker289's Avatar
Cracker289
Dave, no there was 2 tire failures. I didn't text you after the second failure because I figured it was getting late in the day and you might already have gone down for a nap before having to get up for work later. So now the Barracuda has two newer tires on one side, the old spare from my Mustang and the used tire from the place in Benson on 301.
Barracuda has manual drum brakes and I'm sure they need to be redone although Marc and Andre don't seem to be on the same page, Marc just wants to redo the original brakes and Andre wants him to upgrade to power disc brakes. Of course in theory I agree with Andre because hands-down power discs are better, yet at the same time I can't argue the point because I'm happily driving around in my Mustang with manual drums since I got the car in 1992.
Andre and Marc pulled the motor Wednesday night, they texted me pics of it laying on the floor in the garage (it was too long and heavy to go on the engine stand, not stable!). The plan is to take it apart and clean it up and do fresh gaskets, repaint the motor, and stick it back in. Andre wants to put in a new clutch and throwout bearing while it's apart. It's not a job I've ever done since everything I've had has always been automatics but it definitely makes more sense to do it now.
The car is a bench seat 3-on-the-tree and does not seem to be very common at all. In fact I think Marc said despite internet searching a few times he has not been able to find another. My guess is that someone special ordered it that way. The oddness of it has them admiring the rarity of the combination and I don't want to step on anyone's feelings, but rarity does not dictate value. You need rarity + desirability for that! But I would still keep it that way just for the cool factor, 3-on-the-tree was looked down on back in the 80's but nowadays most younger people have never seen one so it's always going to be a conversation piece.
Old Nov 25, 2022 | 05:51 PM
  #34
FuzzFace2's Avatar
FuzzFace2
I dont have an issues with non-power all drum brakes as that is what my Gremlin has and it has a v8 from the factory.
I went thru the brake system before I got it on the road.
It stopped straight and I could lock up all 4 tires if I wanted to.
So I dont see any reason to swap in power disc so I am with Marc.
I will have to reach out to them as I have a motor stand they can use for the motor to get it off the ground.
I will give a look in day light as I got 2 or 3.
I think the 3 on the tree and bench seat is cool.
The 68 Dodge van I learned to drive in and drove had a 225 six & 3 on the tree.
I also had a 65 full size Chevy wagon with a 250 six and 3 on the tree & what was left of a bench seat.
I thought it strange a full size car no less a wagon had a standard transmission but was a cool car.
Dave ----
Old Nov 25, 2022 | 05:56 PM
  #35
FuzzFace2's Avatar
FuzzFace2
Think the one I used for my 300 is handy to get to.
Yes replace clutch assy when there.
I did on mine and the old assy. still looked good but there was no way I wanted to mess with that big heavy truck transmission if I did not have to.
Turned out I had to swap out the transmission for a good one so added the over drive then LOL
Dave ----
Old Nov 25, 2022 | 11:59 PM
  #36
Cracker289's Avatar
Cracker289
That is great I know he will be happy to have an engine stand he can use for this motor. Currently on a lift he has in the garage for working on riding mowers, it holds it nicely but there is no way to rotate it over to remove the oil pan, etc.
Old Dec 12, 2022 | 07:36 PM
  #37
Sparky83's Avatar
Sparky83
So.... i did a thing today.
Old Dec 13, 2022 | 01:14 AM
  #38
Cracker289's Avatar
Cracker289
Hey Shawn congratulations!!
Old Dec 13, 2022 | 05:54 AM
  #39
Sparky83's Avatar
Sparky83
ty ty.. told her shes mine now forever.
tiny1
Nebraska Chapter
120
Sep 1, 2022 08:09 AM
tiny1
Nebraska Chapter
140
Jun 30, 2022 04:19 PM
Nighteyez
N. California Chapter
76
May 31, 2021 10:37 PM
Sparky83
Nebraska Chapter
1007
Apr 1, 2016 09:58 AM
