Where did it go?
Old Oct 6, 2022 | 07:07 AM
Lincoln05's Avatar
Lincoln05
Where did it go?
Had my 2017 CCSB 6.2L in for service due to difficulty shifting into drive. It would shift, go 10-20ft, and then the transmission would lock up to a skidding stop in 1st. Otherwise shifted fine once I got going.
Transmission was down 3 quarts. No sign of a leak anywhere. I park in a garage and not a drop of fluid to be seen. Checked the transfer case to confirm it wasn’t full of fluid (bad input shaft seal), and nothing….
I’m stumped. Any thoughts?
Old Oct 6, 2022 | 07:16 AM
cpobst's Avatar
cpobst
I hate to ask a dumb question but has it been serviced before and do you know if it was ever filled to the proper level?
Old Oct 6, 2022 | 07:21 AM
Lincoln05's Avatar
Lincoln05
Good questions. I’m at 55k. Never had the transmission serviced. The last time I had checked the fluid it was probably around 30k. All was good then. I bought it new with 20 miles on it in 2018.
Old Oct 6, 2022 | 08:09 AM
Joe T's Avatar
Joe T
I had a dodge that did that. Perplexing but maybe it had a small leak on the top. Would use a little fluid between oil changes.
The cooler isn’t in the radiator so that isnt a point.
Old Oct 6, 2022 | 08:34 AM
redford's Avatar
redford
FTE Leadership Emeritus
Either you have a transmission fluid leak that you haven't yet detected, or your transmission has an internal black hole that is eating your fluid.
Old Oct 6, 2022 | 08:38 AM
Grass Lake Ron's Avatar
Grass Lake Ron
My grandfather had a 2+2 that did the same thing with oil. No leaks, no burning....just ate it.
Old Oct 6, 2022 | 08:53 AM
redford's Avatar
redford
Pontiac 2+2? Wow, one of my dream cars is a 1965 2+2.
Old Oct 6, 2022 | 08:59 AM
Grass Lake Ron
Yes a Pontiac 2+2 in black. 421 tripower.
Old Oct 6, 2022 | 10:25 AM
Sport45's Avatar
Sport45
The engine could eat the ATF in the older cars when the vacuum modulator leaked. Nowadays it’s hard to imagine the fluid disappearing without a trace. Even if it was puking out the vent you’d see the trails.
TLinville85
6.7L Power Stroke Diesel
Jun 21, 2021 07:24 PM
djordan
15
Dec 11, 2013 09:42 PM
Dancingchicken
Jun 9, 2010 07:57 AM
cv18sro
1997 - 2003 F150
Oct 8, 2009 06:35 PM
MooreFord
Dec 30, 2004 02:54 PM
