Hi, new here, I have a 95 f250 with the 7.3 powerstroke, it’s pretty clean overall however is lacking in a few areas notably the interior, I have an opportunity to purchase a 1990 f250 with the 351 in it, same red interior, it is not clean at all and as such is at a very low price and worth it to me to get the dash pad as well as bench seat (which are clean in this truck and not my own). I just want to make sure that these are in fact the right parts and that the interior didn’t change drastically between 90-95. I would just go look at it to compare, but it is a couple hours drive. Wondering if anyone else has experience here, thanks in advance!
Way different. A 20 second internet image search will show that the only common part is likely to be the headliner so long as the cab style is similar.
Can it be done? Probably...but your biggest hurdles will be the dash/cluster wiring and steering column mounting.
The interior did change - a LOT. You'd be better off getting the parts you need to fix your current interior out of the scrap yard or off somebody parting a truck out.
Thanks for the info, I was looking online it seems like the window is 92-98 for that interior style. Should’ve looked a little harder I suppose, really appreciate the help though
Yes. 1987-91 is one body style and interior. In ‘92 the body and interior changed. It was that way until ‘96 on the Bronco and F-150 when they got redesigned. The F-250/350 kept that design for another year (‘97).
