Sponsored by: Real Truck
random codes 0171 and 0174
Old Oct 5, 2022 | 02:14 PM
Domino's Avatar
Domino
2016 6.2L with 86,000 miles ran perfectly until 2 weeks ago when I filled up with Chevron 87 octane. Within 2 miles of leaving the station the engine started to bog, surge and rattle under light accelaration. I figured bad gas. Put in some 104 octane and truck seemed to run better. Filled up yesterday with Exxon 87 octane and still getting engine rattle under light acceleration and a very random code 0171 and 1074. Cleared the codes but they keep popping up very randomly, maybe once every 3 or 4 days. clear them and they go away for a few days, .. BTW this truck has run flawlessly on 87 octane since day one...
Thoughts ? suggestions ?
Old Oct 5, 2022 | 02:33 PM
bajaphile's Avatar
bajaphile
Both banks running lean, you have a good possibility that something upstream is causing it. I would do a very good check for cracked hoses that lead to the intake, loose connections on hoses and intake, etc. Even check your oil fil cap. You most likely have a vacuum leak somewhere which is causing unmetered air to get in past the MAF. If everything checks out, might want to clean the MAF just in case it is sending a faulty signal.
Old Oct 5, 2022 | 03:07 PM
redford's Avatar
redford
FTE Leadership Emeritus
I don't think your error codes are related to the quality of the fuel you purchased. Was anything touched under the hood during the fuel stop?
Old Oct 6, 2022 | 08:03 AM
Djosbun's Avatar
Djosbun
Monitor the upstream O2 to see if it’s switching slow. I just replaced the upstream bank 2 sensor on an Ecoboost Explorer that was causing a lean DTC due to a lazy O2 sensor. You’ll need a good scan tool or Forscan to watch the activity in graphing mode (which is easiest, IMO).
— Dave
Old Oct 6, 2022 | 09:55 AM
WWR's Avatar
WWR
Yep likely vacuum leak
FTM has a vid about the air boxes -- at least on the 6.2's -- not sealing well and causing problems, too
Colorado_Kid
6.2L V8
38
Jun 16, 2024 08:50 PM
rcknrbn
2009 - 2014 F150
13
Aug 30, 2018 04:35 AM
abah
2004 - 2008 F150
13
Oct 28, 2011 05:06 PM
mikfitz
5.0L Coyote
Oct 23, 2011 07:35 PM
skilife17
1997 - 2003 F150
Mar 19, 2006 03:42 PM
