6.2L V8 Discuss the 6.2L V8
Is Higher Octane Better
Old May 20, 2019 | 01:41 PM
Colorado_Kid's Avatar
Colorado_Kid
My trucks say to use 85 octane however the lowest I have found is 87 and has been fine. Is it alright to go higher or should I stay with the regular 87?
Old May 20, 2019 | 05:53 PM
Chuck's First Ford's Avatar
Chuck's First Ford
what year, what engine ? your information is empty..
85 octane.. you UP in the mountains ?
I could guess 6.2L Gas... but in today's world .. I could be wrong.
Old May 20, 2019 | 06:04 PM
Colorado_Kid
I live in Vail. My truck is a F-250 XL with 6.2L V8 engine.
Old May 20, 2019 | 06:54 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I'm think it's 87 minimum octane and E85 alcohol blend.
Denny
Old May 21, 2019 | 09:08 AM
acadianbob's Avatar
acadianbob
I would never use less than 87. On the other hand, going above 87 provides minimal to no benefit.
Old May 21, 2019 | 10:38 AM
NWnative's Avatar
NWnative
Your manual also recommends 91 or better octane for 'best performance' when towing or in hot weather. Just follow what your manual recommends and don't overthink it. Agree with others...nothing less than 87.......
Old May 21, 2019 | 08:21 PM
saratoga2011's Avatar
saratoga2011
Don't use that 85 octane fuel you find at high elevations.
87 or higher.
Old May 21, 2019 | 08:33 PM
Chuck's First Ford
READ and or search..
< google > why 85 octane in the mountains.
here is 2
https://tap.fremontmotors.com/truste...se-at-altitude
https://www.quora.com/Why-is-regular...ion-U-S-states
Old May 21, 2019 | 09:46 PM
Colorado_Kid
Thanks for all the advice.
Old May 22, 2019 | 08:59 AM
geekwithoutacause's Avatar
geekwithoutacause
Originally Posted by NWnative
Your manual also recommends 91 or better octane for 'best performance' when towing or in hot weather / high elevation. Just follow what your manual recommends and don't overthink it. Agree with others...nothing less than 87.......
If you live at a higher altitude a lot of gas stations sell 85 octane gas. At higher altitude this is ok to use instead of 87.
What the manual states for using at higher altitude to use HIGHER octane gas doesn't make any sense. Perhaps they assume you are towing/going up hill a lot.
Whatever it is, I've used 85 in many cars at high altitude and it's been fine.
Old May 22, 2019 | 11:45 AM
crewzer's Avatar
crewzer
Exclamation
The OM for your 2015 F250 6.2 “recommends” 87 AKI fuel, and specifically recommends against 85 AKI. See OM pages 140 and 141.
Ford began including the higher AKI recommendation for “best performance” for MY2017 when they introduced the improved 6.2.
I’ve not seen any recommendation to use “higher AKI fuel at higher elevations”.
HTH,
Jim / crewzer
Old May 22, 2019 | 10:29 PM
acadianbob's Avatar
acadianbob
here is 2
And using information out of the link you provided . . .
Is 85 Octane Ok To Use At Altitude?
It seems there is not a definitive answer to this as far as modern vehicles go (anything without a carburetor).
The EPA says on their website, “The sale of 85 octane fuel was originally allowed in high-elevation regions—where the barometric pressure is lower—because it was cheaper and because most carbureted engines tolerated it fairly well. This is not true for modern gasoline engines. So, unless you have an older vehicle with a carbureted engine, you should use the manufacturer-recommended fuel for your vehicle, even where 85 octane fuel is available”.
85 Octane is old school . . . . Ford says never use less than 87 octane.
Old May 23, 2019 | 08:41 AM
geekwithoutacause
And yet, every possible gas station around me sells either 85 or 86 octane fuels and everyone is using them. No issues at all. This is at 6500 ft and up. I've been using the 85 and 86 on the various vehicles, never an issue.
Old May 23, 2019 | 12:20 PM
crewzer's Avatar
crewzer
Modern engines will likely retard ignition timing to compensate for low AKI fuel, and the engine will probably appear to operate without issue. However, power and fuel economy will likely suffer.
HTH,
Jim / crewzer
Old May 23, 2019 | 12:22 PM
geekwithoutacause
HTH,
Jim / crewzer
I'm sure they do, on top of the hit for the altitude. Used to drive s stick shift na car. Absolute dog at this altitude. Now have a turbocharged car which is night and day.
