1995 A/C Compressor
Old Oct 4, 2022 | 06:16 AM
GasGuzler's Avatar
GasGuzler
1995 A/C Compressor
So I’ve been planning on getting the A/C to work in my 1995 F-150, I recently did a radiator support swap and there was nothing in the system at all, I had tried to get the compressor to work but it never engaged, is there a safety shutoff for it if there is nothing in the system? If I do have to end up replacing it is there a way to hotwire one of them to check if the clutch engages?
Old Oct 4, 2022 | 06:49 AM
rla2005's Avatar
rla2005
Yes there is: A/C Clutch Cycling Pressure Switch.
Jumper the A/C Clutch Cycling Pressure Switch
For reference:
Old Oct 4, 2022 | 07:23 AM
My4Fordtrucks's Avatar
My4Fordtrucks
As was already stated, there is a low pressure switch preventing the clutch from energizing. That is the switch that you can momentarily jump to see if the clutch works. R-134a also has a high pressure switch, by the compressor, that will cause the clutch to turn off if the pressure is too high.
V10man
Apr 22, 2013 10:52 AM
pukemon
2004 - 2008 F150
25
Aug 11, 2007 12:30 AM
71FoMoCo
Jul 18, 2007 12:38 AM
ubermich
Jul 2, 2004 03:29 PM
ncvote
Mar 2, 2002 11:24 AM
