Okay, I missed the spring clamp at the base, my BAD.....So leave the top clamp on and remove the bottom one. So this goes to the firewall and connects to what? I plan on changing out the air intake manifold on top, and changing out some hoses. Has anyone used a temp. fix for a head gasket repair until a guy can round up enough cash to do it??
I had no idea there was a restrictor there, that is good information!
If it wasn't securing a restrictor, those clamps just need to be snipped with some dikes or with the installation tool which has a cutting feature. (Similar to PEX piping clamps).
As far as using a temp fix for a head gasket repair... ugh. I have heard that the stuff in the can "works", but, not from personal experience. You run the risk of it causing more damage or not doing anything at all.
Personal experience is these "TEMPORARY FIXS" cause collateral damages by starting to block passages that shouldn't be, and many times are used to long and cause more damage in the end. I learned this when I was young the hard way. Blew the bottom end out of a 302 running Bar's Leak in a Mercury Comet years ago. Had put it in and a week later waiting for payday and it puked (poor married sailor) on the way home. Newer engines are even more susceptible to issues.
Others will tell you they never had an issue.
Your truck and you'll have to make the decision so good luck.
These are the horror stories that make me nervous to use these kinds of 'fix in a bottle' type solutions. I HAVE used the radiator repair stuff for short periods to slow down some leaks until I was able to properly repair them, but not for long term - meaning a couple weeks at best. And I've never put in as much as they recommend for exactly these kinds of reasons.
I would suggest that if you have the ability to just park the truck until you can fix it right, do so. If not...you are on borrowed time no matter what you do. Given the expense of these engines if something fails...I'd rather not risk it myself.
