Starter issues. Some insight please.
Old Oct 8, 2022 | 11:28 PM
  #31
5starCabF-3's Avatar
5starCabF-3
It is OK the ring gear is shot and the flex plate will have to be replaced....so it has to come apart.
blow up the pic of the ring gear through the starter opening
Old Oct 9, 2022 | 07:23 AM
  #32
FuzzFace2's Avatar
FuzzFace2
I dont know but the teeth dont look all that bad but thats me
Dave ----
Old Oct 9, 2022 | 08:57 AM
  #33
Max Capacity's Avatar
Max Capacity
All I can say now is,
Originally Posted by FlyJSH
Old Oct 9, 2022 | 11:27 AM
  #34
TGiordano87's Avatar
TGiordano87
8th Gear
Thank you everyone for the insight. I’m just trying to get this running, but the plan I have is a buddy of mine and I are going to do a engine swap during this winter. So getting the starter was just something to do.
Old Oct 9, 2022 | 01:20 PM
  #35
Max Capacity
In post #28 you said you got a new starter from a different vendor. Did that starter work ok ?
Did you or someone cut that piece off the shield that appeared to be bent in the earlier photos ?
Old Oct 9, 2022 | 01:56 PM
  #36
TGiordano87
8th Gear
we cut the shield off, have a new flex plate on the way. This afternoon we’re gonna throw in the. We starter from the different vendor.
Old Oct 9, 2022 | 04:47 PM
  #37
Franklin2's Avatar
Franklin2
What you can do is get a big screwdriver, and if you can wedge it in there someplace, pry the starter toward the engine while the bolts are a little loose, and while you keep pressure on it with the screwdriver, tighten the bolts. That might last a couple of starts before it pushes the starter away from the engine again.
Old Oct 9, 2022 | 08:05 PM
  #38
5starCabF-3
Dave ----
look closer Dave...
Old Oct 9, 2022 | 09:28 PM
  #39
Franklin2's Avatar
Franklin2
The teeth are a little chewed up where the starter has been missing them, but I think they will still work if the starter was moved over where it's supposed to be. Keeping it there is going to be the problem.
cannothinkofaname
19
Aug 20, 2022 03:51 PM
Tim Hodgson
1978 - 1996 Big Bronco
Nov 20, 2021 05:51 PM
Spktyr
55
Dec 28, 2016 08:56 AM
PStruwing
Oct 28, 2012 03:58 PM
PStruwing
Apr 9, 2012 10:59 AM
