Sponsored by: Auxito
Cold air intake
Old Oct 2, 2022 | 01:20 PM
Sabrina Ragan's Avatar
Sabrina Ragan
Cold air intake
I swapped out my hot air intake for a cold one what steps should I have taken to be sure my computer in my f150 recognizes it
Old Oct 2, 2022 | 05:33 PM
Conanski's Avatar
Conanski
No action necessary, the computer adjusts in real time for any variation in things like intake air temp.
Old Oct 3, 2022 | 07:39 AM
STOFFERJ's Avatar
STOFFERJ
So you went back to the factory air inlet? datalogs show there really isn’t much adjustment other than what the ecm does for iat temps
if nothing else unhook your battery turn the headlight switched on for about 20 minutes turn the headlight switched off hook the battery back up (negative cable first and last) And then go do a drive cycle
Old Oct 4, 2022 | 10:26 PM
steve(ill)'s Avatar
steve(ill)
so WHAT FACTORY F150 has a HOT AIR INTAKE ????
Old Oct 10, 2022 | 05:09 PM
STOFFERJ's Avatar
STOFFERJ
lets try posting while sober in the future…
Old Oct 11, 2022 | 09:11 AM
Johnny Paycheck's Avatar
Johnny Paycheck
There’s no need for all these gymnastics. None.
Just pull the fuse for the computer for a few minutes, put it back in, go in your way.
Old Oct 11, 2022 | 04:45 PM
STOFFERJ's Avatar
STOFFERJ
easier for most folks to find the battery cables though
Old Oct 12, 2022 | 12:33 PM
Sabrina Ragan
First of all I am sober, I also am an amateur female in her 40’s that knows nothing about the names of technicalities of automotive terms. I’ve learned everything that I know, which isn’t much all from this site and my Hayes and my truck being broken down since January. So basically I replaced my original air filter system for a kln, And I assumed it was a cold air system of some type instead of hot because if my face is leaning over it it doesn’t seem to get my face warm like the other did. So if you don’t have any other “helpful” suggestions for a person like me then don’t bother typing anything. Thank you for insulting me
Old Oct 13, 2022 | 05:20 AM
STOFFERJ's Avatar
STOFFERJ
so my reply to steve(iii)offended you? (one can’t make this stuff up)
and now you’re telling us you installed a hot air intake and the truck won’t run? or the truck had issues before? maybe you should explain the whole situation with some details since most folks can’t see thru the internet or read minds
Old Oct 13, 2022 | 03:03 PM
Airborne 82nd's Avatar
Airborne 82nd
I thought he was talking about the typos. Not the OP
colorado99_f250
39
Feb 7, 2010 07:42 PM
LARIAT 85
Dec 11, 2006 08:39 AM
wideopen
1997 - 2003 F150
Nov 28, 2003 01:04 PM
