PAINT TALK
Old Oct 4, 2022 | 09:08 PM
440 sixpack's Avatar
440 sixpack
You can DP prime it before or after body work. I live in the high desert and have a heated almost air tight shop so rust is not an issue, I do my body work first. but if I had worries about rusting in the shop I'd DP it first. bondo sticks as good or better to epoxy but it never made sense to me to prime it then sand and grind half of it away. but that is he common practice today.
Grinding the paint of is fast and can be destructive. I'd never do it. if you do really watch the sharp edges you can screw them up fast. use a good flexible disc and be careful. plan on extra primer to fill the scratches, and ugly shrink back as well. in a year or two . I can usually tell you who used a grinder , metallics especially.
Old Oct 6, 2022 | 09:17 AM
headloct's Avatar
headloct
Use these instead of grinding discs.Way less damage to the metal.
https://www.harborfreight.com/4-1-2-...abrasive+wheel
Don't linger in any one place to cause heat and warp.Get all the rust off,look close for rock chip rust as it will eventually come back through.Wipe down with phosphate before priming with something like Phix.Epoxy primer is nice but hard to lay on correctly...really tough to sand if you don't.
Old Oct 6, 2022 | 10:30 AM
flowney's Avatar
flowney
I have a CONTOUR SCT® Surface Conditioning Tool from Eastwood that I plan to try out.
https://www.eastwood.com/eastwood-co...ory-drums.html
Since buying it I see thet Harbor Freight sells a similar tool for less:
https://www.harborfreight.com/9-amp-...ool-58079.html
... but with less selection in drums.
I plan to us mine when I get my truck moved to new residence.
Old Oct 6, 2022 | 10:36 AM
440 sixpack
That's another advantage of dustless blasting, it leaves a perfect tooth for whatever primer you prefer. no scratches no shiny spots no then edges. just a 220 grit uniform surface.
1976 F350
Paint & Bodywork
Feb 5, 2022 05:06 AM
Itsmyford
Paint & Bodywork
May 20, 2020 01:34 PM
gbcurrie
2009 - 2014 F150
Jan 16, 2019 10:56 AM
BTclassics
Paint & Bodywork
16
Jul 4, 2017 07:45 AM
bigcrunch
13
Feb 9, 2016 06:07 AM
