Fuel Filter on 95 F150
Old Jun 15, 1999 | 11:27 PM
Paul Johnson
Guest
Posts: n/a
I just spent 3 hours trying to remove the fuel filter on my 95 F150 extended cab. I have the correct tool, and was able to remove the outlet without too much hassle, but was not able to get the inlet side apart. Finally I gave up, and put it back together. Luckily it does not leak.
Any suggestions?????
Thanks
Old Jun 16, 1999 | 05:53 AM
Ron-Bo
Guest
Posts: n/a
I had a nasty little problem like yours on my fuel rail connections. It just took a lot of new "colorful" phrases, and some perseverence, but the lines finally came apart. Keep at it, and press harder.
Old Jun 16, 1999 | 10:08 AM
ajd
Guest
Posts: n/a
I had the same problem on my '96 Reg. cab. My filter is inside the frame-rail about the front of the bed. I also had the disconnect tool from Autozone. I couldn't remove either line and gave up also after about an hour. The other person who replied said to try harder. Trust me I was giving it all I had considering the amount of room available under there. Let me know what you find out, as I am in the same boat as you. Good luck.
Old Jun 16, 1999 | 11:09 PM
john's Avatar
john
I recently manage to get mine changed. I've got a 95 F-150, XLT/Off Road which come with skid plates. After trying to squeeze between the frame rail and the skid plate for about an hour I finally decided to take the skid plate off (which took some time) thinking that now it would be a snap. Ya right!! Well any way I had to round off the open end of the "special tool" where it slips over the fuel line and thing out the end that slips into the clamp area. and then it still took alot of pushing, twisting, foul language. At one point I was about ready to just replace the entire fuel line!!!! Modify your tool, and dont get the plastic ones, find one thats made of metal. Good Luck
Old Jun 17, 1999 | 09:37 AM
Phillip Guidry's Avatar
Phillip Guidry
SNAP-ON makes a plier style tool for this. You can really apply lots of pressure with this one. Maybe other brands like MAC Tools or MATCO will offer the plier style also.
Phillip
Old Jul 18, 1999 | 03:01 PM
ntkemmerly's Avatar
ntkemmerly
I changed the frame mounted fuel filter on my truck with similar perseverence. Then I started looking for a better way. The next filter change was easy (20 min). The fuel filter clips into a bolt on frame bracket. This bracket is made with studs that pass through holes in the frame and secured with nuts. Remove the mounting nuts. Insert the special fuel line removal tool on the front side of the filter and disconnect the fuel line. Insert the fuel line removal tool on the rear side fuel line to release fuel line lock. Carefully remove the filter and bracket together. Reassemble in reverse order.Good Luck
Old Aug 18, 1999 | 01:29 PM
Chris Lafleur
Guest
Posts: n/a
I own a 94 F-150 regular cab and had a helluva time removing my filter....With NO special tool....What is this special tool??....anyone know what is it called or look like....
Old Aug 18, 1999 | 01:52 PM
LARSON's Avatar
LARSON
I am not sure exactly if you have the same ones as I recently took off or not. The metal end connectors of the ones that I did had a piece of metal that looked similar to a cut hose clamp. I simply removed this internal 'clip' with a small/tiny screwdriver. You can reassemble the end to put it back on once you get it off.
Old Aug 18, 1999 | 02:50 PM
paul tankersley
Guest
Posts: n/a
MONAVIERONJON
20
May 4, 2017 08:49 AM
Doostien
Nov 16, 2014 06:20 AM
johnsonswamp
Nov 21, 2012 08:28 PM
mtntop1
Jul 23, 2011 02:23 PM
F0rdF0rever
Sep 30, 2003 07:52 PM
