While I replace the thermostat…
Old Sep 29, 2022 | 07:52 PM
simplyvince's Avatar
simplyvince
77 F150 460 no mods.
Pretty sure my thermostat went and maybe my water pump. It was running cool last time I drove it. Now it's leaking a little around the hose to water pump connection. Haven't had the time to investigate too much.
If I do have to replace the thermostat, what else should I tackle?
If I have to replace the water pump, what else?
I've seen better oil pumps, straight up timing chains, and drive pulleys replaced while you're there.
Old Sep 30, 2022 | 10:01 AM
beartracks's Avatar
beartracks
Water pumps will ususally leak out the weep hole and make noise when bad, unless the impeller is rusted out. Clamps sometimes need retightening.
Old Sep 30, 2022 | 04:53 PM
simplyvince
Good to know.
Old Oct 1, 2022 | 02:24 PM
i-w's Avatar
i-w
I got the fllowkooler water pump from bronco graveyard site.
Seems to work well.
Old Oct 1, 2022 | 02:25 PM
simplyvince
Seems to work well.
you use their thermostats too? Seems to be motorad is the way to go these days for stats but curious about flowkooler in general.
Old Oct 1, 2022 | 02:39 PM
i-w's Avatar
i-w
I just realized you got a 460... SORRY, might not help much.
BUT the Flow Kooler Water Pump seems to work well for me.
460 flow kooler water pump
https://flowkoolerwaterpumps.com/col...460-water-pump
i got the thermostat from Tmeyerinc. he is very knowledgeable person on the 351m. so i got it from his site.
Thermostat i got for a 351m
https://www.tmeyerinc.com/product/thermostat-bundle/
Home page
Old Oct 2, 2022 | 04:16 AM
Ozzie H.'s Avatar
Ozzie H.
I'd replace only what needs replacing. You can check the thermostat with a known good thermometer in a pot of water on your stove. Perhaps the leak in the hose to water pump connection may only be due to a loose clamp. Water pumps usually need replacing because the seal or bearing have failed. If the bearing is solid (& silent) and there is no leak, it may not need replacing. Impeller problems are less common. Oil pumps and timing chains are more involved. Drive pulleys usually don't fail.
Old Oct 2, 2022 | 12:57 PM
simplyvince
solid advice. Thanks!
Old Oct 2, 2022 | 01:21 PM
tbear853's Avatar
tbear853
Gasket, coolant mix, & look close at hoses too.
Old Oct 2, 2022 | 01:59 PM
Yamhill Ranger's Avatar
Yamhill Ranger
My truck is your's twin. I assume you have a trailer special?
back on topic:
I recently did the T-stat and rad hozes on mine. I would recco you do the tstat unless you know it's history. cheap insurance (oh, but do check your new one prior to install just cause you never know....)
I used motorad 5200-180. I also drilled a 1/8" weep hole in mine prior to install. I'm using the victor reinz o-ring style water neck gasket for the first time. It's a dry fit which I like. I changed the bolts while I was in there as the old ones were a bit rusted. Use a steady draw torque (NO IMPACTS) to break those bolts free. Don't go hog wild torquing the water neck down. 10-12 lb-ft max for a grade 5 bolt.
Old Oct 2, 2022 | 08:28 PM
simplyvince
back on topic:
VIN and wheelbase says just a regular Ranger. Good tips and was looking at that same HD Motorad you got. Couldn’t decide between HD and the Premium cause the fail-safe on “Premium” but would rather have the longevity of the HD.
simplyvince
Oct 10, 2022 11:10 AM
JoeF250
Sep 14, 2021 06:54 AM
mikec91
Nov 12, 2013 07:31 PM
jaye
Dec 16, 2012 02:32 PM
kawika
May 9, 2006 08:30 PM
