help leveling kit options
Old Sep 29, 2022 | 11:11 AM
Rhorn61's Avatar
Rhorn61
4wd High
i Know the truck is a 2wd with twin i beam and i want to at least take the rake off the front and raise it 2 inchs by doing that what are some options and kits i can buy that wont mess up the camber and make my coil springs bend inward or outward plus can yall post some pic of yalls ?
Old Sep 29, 2022 | 01:49 PM
sandymane's Avatar
sandymane
I see you have an F250 2WD. On my 91 F250 2WD, I tried a 1 1/2" spacer and found my knuckle on the passenger side would not allow enough camber adjustment to be properly aligned. The 4WD has plenty of adjustment but not the 2WD. Adjustable casters for 2WD only offer about 2 degrees of adjustment. Using adjustable casters on a 4WD offer about 4 degrees of adjustment. I put new shocks and new coil springs on when I removed the spacer and got it level. I don't know of any other way to get it level.
Old Sep 29, 2022 | 01:53 PM
Rhorn61's Avatar
Rhorn61
4wd High
so you put longer springs plus shocks?
Old Sep 29, 2022 | 01:55 PM
Rhorn61's Avatar
Rhorn61
4wd High
how long are those springs can you send a link
Old Sep 29, 2022 | 01:56 PM
sandymane's Avatar
sandymane
No they are both stock size but the shocks are Moog progressive springs. Take a look at the camber and knuckle on your 96 as it may be different since the 91 was a cut off year.
I put a pic of mine in the last post.
Old Sep 29, 2022 | 02:22 PM
sandymane's Avatar
sandymane
Can't find any info about length. They are MOOG CC845 Progressive shocks. You can call Moog and ask them about specs. They are very helpful.
CONTACT US
Customer Service, General Inquiries, Product Support
SUPPORT
Technical Information
Need help installing a product? Want to know the specifications for a part? Call the Technical Line for the product support you need to get the job done.
1.800.325.8886
Monday – Thursday: 7:30 a.m. – 4:30 p.m. (CST)
Friday: 7:30 a.m. – 4:00 p.m. (CST)
Old Sep 29, 2022 | 09:04 PM
Rhorn61's Avatar
Rhorn61
4wd High
So you had a 1.5 inch leveling spacer took it off and now all you put was new springs and shocks?
Old Sep 29, 2022 | 09:56 PM
sandymane's Avatar
sandymane
Yes. When I put the shocks and springs on, my goal was to improve the ride. They worked and I had a level truck as a bonus. YRMV
Old Sep 30, 2022 | 08:29 AM
jas88's Avatar
jas88
You will not get any kind of lift on the front without having to address camber.
Old Sep 30, 2022 | 09:38 AM
sandymane's Avatar
sandymane
Right. I forgot that very early on I had bought new camber bushings that gave me the slight 2 degrees adjustment that was available. So, with the new shocks and springs replacing older sagging components and the slight 2 degree bushings, my truck is level now and not actually raised.
MDK993
Oct 22, 2020 12:33 AM
Michael Pace
Jul 7, 2013 08:47 PM
Setty7
1997 - 2003 F150
Nov 12, 2009 10:32 PM
f2fifty83diesel
15
Jul 15, 2009 11:16 PM
