So, some background, I just bought this truck that has sat for about 9 months. I knew it had this issue its a 4.9, and basically it will start run and drive when cold, but once it gets to operating temp, it will sputter and shut off. If I let it cool down, it will start again, and drive for about another 8-10 minutes. The cel is on, and I ordered a scanner that will be here Saturday. The truck only has one cat on it at the moment, and has just distilled water in the radiator. Also, the gas gague is not accurate, but I'm not sure if that is part of the problem.
plans
Currently I'm going to put the 50-50 back in the radiator, replace the thermostat as it's only $8. And use the scanner to check the cel
Well when the truck shuts off when hot, check for spark at the plugs could be something electrical breaking down when it gets hot. Check for fuel pressure could be a vapor lock and or pump or relay shutting down when it gets warm.
It's a 1993
And i will check on those. I think it has new plugs and distributor, but I'm not sure about wires. What is the best way to check fuel pressure?
