Single Throttle Body?
Old Sep 29, 2022 | 12:49 AM
Bossman583's Avatar
Bossman583
I’m brand new to the forum after only having negative input on Facebook. I’ve got a 1996 f-150 with a super tired 5.0. I want to keep the truck as long as possible so I plan on rebuilding the engine. I’m going with a 347 built as hot as I can but still having good manners. The eddy truck intake is out of stock everywhere so I’ll just get a performer rpm and flip the intake to the drivers side. How hard is it to switch to a single throttle body. Do all the vacuum/ coolant lines swap right over? Thanks y’all!
Old Sep 29, 2022 | 02:33 AM
TexasGuy001's Avatar
TexasGuy001
That should be just about identical to a Lightning setup. The only real issue I can see is the throttle cable being different and maybe the EGR stuff. The vacuum and coolant lines shouldn't be a big deal to reconnect to the necessary ports.
Old Sep 29, 2022 | 07:08 AM
R&RFord's Avatar
R&RFord
I have an intake, throttle body, and a harness for this project. I may have other odds and ends.
The GT40 setup has all the same parts as the trucks they are just moved around. The main part I think you need is a throttle cable and bracket from a lightning. The rest of it can be modified from what you have or can be had aftermarket. An air filter box and tube from a lightning would be nice.
Yout coolant and vacuum tubes will have to be rerouted and shortened or lengthened as appropriate.
Old Sep 29, 2022 | 09:38 AM
Bossman583's Avatar
Bossman583
Do you have the throttle cable and bracket from a lightning? Getting the cable will be fine, idk where to find a cheap bracket. eBay prices are crazy
Old Sep 29, 2022 | 10:18 AM
Scndsin's Avatar
Scndsin
I would guess that probably a 95-6-7 Explorer V-8 might have a throttle cable set-up that could be used in a truck application.
That would be easier/cheaper than a lightning part.
Never really paid attention when harvesting, but I think I'll look closer next JY trip.
Old Sep 29, 2022 | 10:30 AM
R&RFord's Avatar
R&RFord
I did, but I already sold them off.
Your best bet is to get on the Lightning groups and ask if anyone has one they would part with.
But I have to say this will not be a cheap endeavor. And while there is a cool factor, there is limited to no performance gain depending on what you are doing compared to the stock truck 5.0 intake.
Old Sep 29, 2022 | 10:52 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
And to add to the last post, why waste the cash on a shorter stroke, shorter rod 347 when a stock 351W is larger in both manners.
I still see plenty of F4TE 351W cores in the yards.
Old Sep 29, 2022 | 11:14 AM
Bossman583's Avatar
Bossman583
[QUOTE=Hit Man X;20574111]And to add to the last post, why waste the cash on a shorter stroke, shorter rod 347 when a stock 351W is larger in both manners.
I still see plenty of F4TE 351W cores in the yards.[/QUOTE
just for the ease of installation
Old Sep 29, 2022 | 12:47 PM
Bossman583's Avatar
Bossman583
even with a 347?
Old Sep 29, 2022 | 12:50 PM
Hit Man X's Avatar
Hit Man X
A 351W bolts right into place of that 302 block.
Stock 302 EFI truck manifold flows very well. Even the stock dual 49mm TB flows well, nearly as well as a single 70mm.
Old Sep 29, 2022 | 12:51 PM
SFaulken's Avatar
SFaulken
even with a 347?
The stock Truck 5.0 Intake flows pretty well, with a 347, you'd be fine with the stock intake, but larger injectors, and an ECU Tune/Replacement.
Old Sep 29, 2022 | 01:30 PM
R&RFord's Avatar
R&RFord
even with a 347?
The Edelbrock I have probably is better than the stock truck intake. It just isn't so much better to necessarily be worth the added expense and trouble to make it work in your truck. That is up to you and your wallet.
If you are on a budget I would highly recommend you start with a good core from a junk yard, and get it done as you can when you can. When it is ready swap em out. If it were me I would build a roller 351, but that is just me. Everything you already have except for the intake and distributor will swap over to the 351.
Marine142
6.7L Power Stroke Diesel
Jul 10, 2021 10:03 AM
firefighter1416
1997 - 2003 F150
Aug 11, 2009 07:05 AM
mac_91
1978 - 1996 Big Bronco
Nov 28, 2008 02:24 PM
lattices2
May 27, 2005 04:10 PM
drift91
Nov 22, 2004 09:11 PM
