Do these trucks run hot?
Old Sep 29, 2022 | 06:31 AM
GM in a Ford's Avatar
GM in a Ford
Why did Ford decide to put functional vents in the fender badges of the 2023 super duty? Do these trucks run hotter than they should? Does the increased power of the 7.3l and 6.7l need more cooling? Not complaining really, just curious why now?
Old Sep 29, 2022 | 06:43 AM
Joe T's Avatar
Joe T
Probably the increased power and ratings. On the 20 drw they run the same high flow grill from XL to Limited. That model had increases as well
speakerfritz's Avatar
speakerfritz
there are a kazillion heat exchange devices in the front end....everything in the engine bay is always hot to touch. planning on a ram scoop hood for my truck. had on on my prior truck and it really cooled things down.
Old Sep 29, 2022 | 06:44 AM
B-ManFX4's Avatar
B-ManFX4
I was towing my RV the other day. ~10,000 lbs. Got stuck behind a bunch of bike riding guys - long, slow climb (10 - 15MPH) up a mountainous ridge. 45 minutes of riding behind them going that slow, ambient temps in the low 80's. Water temps got up to 216° and the transmission got up to 212°. I didn't feel like that presented any issue at all. We were running the AC the whole time too.
Old Sep 29, 2022 | 07:10 AM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, they do, especially the transmissions. This is by design, engineers have found that the power train is more efficient at high temperatures. All those heat exchangers are there to keep the truck from getting too hot in the worst case conditions, like a tow climb on a long steep grade behind a pack of bicycles.
I just wonder what kept the driver cool. I would have been a little hot under the collar if that happened to me.
Old Sep 29, 2022 | 07:36 AM
chadstickpoindexter's Avatar
chadstickpoindexter
So I gotta admit… I thought the current fender badges were functional… this was one of the reasons I had put off getting one of the Ikonic Badges… they looked flat rather than recessed and didn’t have the vents… turns out, I guess that doesn’t matter! But, I really want a fender badge from billet badges… but dang… $485 and a 12-18 week wait…
Old Sep 29, 2022 | 07:55 AM
B-ManFX4's Avatar
B-ManFX4
At first I was getting irritated. As it dragged on I did start to get antsy. At one point there was a short passing zone - I stepped on it and when it downshifted it broke the tires loose and wheel-hopped a couple of times before I let off. Unbelievable it has the torque to do that with over 1,200 lbs. of tongue weight. That was enough to re-engage my patience for the remainder of the journey. So glad I didn't break something.
Old Sep 29, 2022 | 08:32 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Agreed. Last time I followed anyone up a long winding climb I ended up stopping...I was in a '98 Pontiac Grand Prix GTP, with the supercharged engine...BIL thought that meant I needed to climb the hill slow, so he went about 10-15 mph. We got about 3/4 of the way up and my radiator fans were running full bore, coolant temps topped 230, and the temp light came on so I just...stopped, and let it idle for 10 minutes to cool things off. Had to explain to him later that with a blower on top of that motor I needed airflow, because in 1st gear all I was doing was boosting.
Old Sep 29, 2022 | 08:44 AM
h20camper's Avatar
h20camper
They are misleading.
Old Sep 29, 2022 | 09:58 AM
Ford8502's Avatar
Ford8502
With the way they've increased the fan speed on the 6.7, and the heat issues on the 7.3 plug wires from heat, I'd say more air is a good thing.
Old Sep 29, 2022 | 10:08 AM
NedFletcher's Avatar
NedFletcher
With my 7.3 it will radiate heat for a hour or two after being driven, so I'd assume it gets hot
Old Sep 29, 2022 | 03:54 PM
Wyldfire's Avatar
Wyldfire
Old Sep 29, 2022 | 04:25 PM
KU4OJ's Avatar
KU4OJ
I did too at first, but gave them a good eyeballing and figured out there was a lot of red paint up in there where the hole should have been.
I'm a little on the fence about having fumes from the engine compartment exiting just below the cab windows. If there were CO fumes leaking or some other stink it might not be good. Not to mention just plain old hot air coming in on an otherwise nice day. Plus I think the oversized badges are less than pretty, along with the side steps.
Gonna hold on to what I got for 19 more years.
Old Sep 29, 2022 | 04:29 PM
scraprat's Avatar
scraprat
Top Answer: 5
Nothing that a drill or dremmel can't fix, go ahead boys if you think the engineers screwed up. Don't forget to video it so others can follow in your engine overheating fix.
Old Sep 29, 2022 | 05:14 PM
Wyldfire's Avatar
Wyldfire
Cutting vents in fender just looks like a sure fire way to suck rain and snow into engine compartment. Heat is the one way Ford is increasing fuel efficiency. The new synthetic fluids can handle heat far better than 90's fluids.
