3 on the tree shifting issues
Old Sep 24, 2022 | 11:20 AM
wilkes704's Avatar
wilkes704
The truck is a 1966 f100. 240, Ford 3.03, three on the tree. I’ve replaced the worn stuff in the steering column. The truck has a new driver side cab mount. The trans will shift into all of the gears at the transmission. The trans will shift into the gears at the shift arms. From inside the cab, the trans shifts into 2nd and 3rd easily, but I can’t get 1st and reverse.
I followed the linkage adjustments instructions in my chiltons manual. “Place the shifter in neutral and insert a gauge pin in shifting arms. adjust sleeves so the shift rods enter shift levers easily. Now lengthen the rods 7 turns and insert into shift levers”. I’ve paraphrased, but that’s the gist of how it’s adjusted.
I got a mint shift tube replacement. The little tab isn’t remotely worn. The shift lever engages with the hole and pushes and pulls on the tube as it should.
anyone got any suggestions on what to adjust or where to look?
Old Sep 24, 2022 | 12:07 PM
wilkes704's Avatar
wilkes704
it should be noted that the shift tube is not an original. The original tab was broken off and just worn, along with some of the other shift tube parts. I had located a mint one from a unibody. The only thing I had to do was put on the little tab that the shift selection lever goes in. I put the tab on the shift hole where the original one for the unibody is. This may be where my issue lies and the tab just isn’t engaging with the key way on the reverse and first shift arm.
Does anyone out there have a measurement from the top of the tab that engages the keys, to the middle of the hold for the shift lever? Mine is 26.75”
Old Sep 25, 2022 | 12:18 PM
Crop Duster's Avatar
Crop Duster
I don't believe anything from a 61-63 steering column will work on a 66. Did you compare it to the old one you removed, close doesn't count.
Old Sep 25, 2022 | 12:29 PM
wilkes704's Avatar
wilkes704
I got it solved! The distance of the hole for the shift arm and the little nub was a 1/16 difference between the unibody and the 66 f100. I just moved the tab for the shift lever hole.
UnfortunateFish
Sep 30, 2019 09:27 PM
ford76460
Apr 14, 2017 04:04 PM
starrider
Sep 6, 2010 09:15 AM
midnight_mp
Jan 20, 2008 05:30 AM
Ron Crawford
1978 - 1996 Big Bronco
Dec 16, 2003 11:30 AM
