Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
vin and axel decode?
Old Jan 3, 2022 | 07:18 PM
john bogart's Avatar
john bogart
4th Gear
1FDNT74P6HVA63305
then the other tag below it states the vin again then exterior70 below that it says WB 187 then type GVW T74245gk8 trans CL axels 53m
Old Jan 3, 2022 | 08:28 PM
85e150's Avatar
85e150
Welcome back. Another run at a decode, and this time I might be of help:
1FD = Ford Motor Co. USA, incomplete vehicle
N = Class 6, 19,001 to 26,000 lbs GVWR, hydraulic brakes
T74 = F700
P = Ford (Brazilian) 6.6 L in-line 6 cylinder turbo diesel
9th digit
H = Model Year 1987
V = Kentucky Truck Plant
A63305 = Serial number
70 = Not shown. Could it be "7D", Holly Green?
WB 187 = 187 inch wheelbase
type GVW T74245gk8 --Run together, I can't figure it out. K742 would be an F700 diesel, 24,500 lbs GVWR
CL = Clark model CL450 five speed transmission
53M
53 = Rockwell model RS-17-140 17,500 lbs capacity rear axle, single speed 4.56 ratio
M = Ford 7,000 lb capacity front axle with power steering
Let me know if this doesn't match up or if you have any other questions. There are several folks here familiar with the Brazilian engines. Find out what kind of hydraulic brakes you have.
Old Jan 3, 2022 | 08:32 PM
john bogart
4th Gear
nope thats spot on its def green loleverything eslse is righh on too its a bucket truck im trying to do king pins on it and find newrer rear springs and i need the lift part the hydrolics hook too under the chipper body its all rotted out thnk you so mush
canyoncat
Large Truck
44
Jan 21, 2022 06:56 AM
Dave588
Large Truck
Nov 29, 2019 11:10 PM
Woody205510
Large Truck
Apr 8, 2019 12:26 AM
gdoakes
Large Truck
Feb 10, 2017 04:22 PM
sth62691
15
Sep 20, 2011 03:41 AM
