Sponsored by: Real Truck
Brake problem
Old Sep 20, 2022 | 08:52 AM
slyluna's Avatar
slyluna
8th Gear
Brake problem
I have a 2011 F250, 103,000, miles and my brakes are not holding on any type of incline. I first noticed it backing a boat on a boat ramp. Major pucker factor. it eventually stopped, but it kept on slowly rolling and it finally stopped. My driveway has a slight incline to it and it does the same. Brake fluid level is fine and brake pads are only a couple of years old. Any ideas? TIA
Old Sep 20, 2022 | 09:18 AM
PJWhelan's Avatar
PJWhelan
Are you engaging the E-Brake? Is it not holding when you are in "Park"? More details are needed.......
Old Sep 20, 2022 | 09:41 AM
slyluna's Avatar
slyluna
8th Gear
The emergency brake holds fine, and when it is in park it also holds. It only does it in neutral or when in gear, D or R.
Old Sep 20, 2022 | 11:23 AM
leadmic's Avatar
leadmic
Is the peddle dropping? Is your truck a diesel or gas?
Old Sep 20, 2022 | 11:28 AM
slyluna's Avatar
slyluna
8th Gear
The pedal does seem like it is dropping. It is a diesel
Old Sep 20, 2022 | 11:35 AM
PJWhelan's Avatar
PJWhelan
If it's dropping than you need to at least bleed the brakes.
Old Sep 20, 2022 | 01:08 PM
Djosbun's Avatar
Djosbun
This is not going to resolve the OPs problem.
— Dave
Old Sep 20, 2022 | 04:07 PM
slyluna's Avatar
slyluna
8th Gear
So yesterday I noticed that on an incline if it is in neutral my brakes will stop the truck. If it is in reverse or drive downhill it doesn't stop. So if it is on an incline and in gear they will not hold. The emergency brake doesn't stop it either like it should if in gear. The pedal feels normal, it is not dropping much if at all.
On my way to work this morning I pulled over on the downhill side of a bridge and it seemed to hold ok. I then drove into a steep driveway and put it in park and then reverse and it doesn't hold very well. It seems like it only happens when I creep down the incline with the weight of the truck and the force of it being in gear.
I appreciate everyone's feedback. I have an appt to get it looked at, but just wanted to see if anyone know's what it could be in order to help with the diagnosis.
Old Sep 21, 2022 | 06:59 AM
slyluna's Avatar
slyluna
8th Gear
Could it just be a caliper or pad issue?
Old Sep 21, 2022 | 07:18 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Really need a bit more info but I'd lean toward your brake booster or the vacuum pump. It's a diesel, so it doesn't create vacuum on its own.
If I recall this issue is usually coupled with the 4x4 not working and/or the defrosters malfunctioning.
Old Sep 21, 2022 | 07:19 AM
99powerstrokedF250
— Dave
While I agree with you, it might be nice if you presented more info than just 'That won't work.' Kinda comes across as a jerk...
Old Sep 21, 2022 | 10:59 AM
Djosbun's Avatar
Djosbun
I rarely throw out silver bullet ideas without the OP supplying additional information (ie- what tests/diags that were done). Who would it help if I say “replace the master cylinder” if that’s not the underlying issue?
— Dave
Pau1
Mar 9, 2020 03:41 PM
skyfox10
Oct 17, 2010 01:52 AM
dcara
Dec 15, 2007 04:07 PM
david c
Jan 10, 2005 06:19 PM
