Corner lamp nut plate
Old Sep 19, 2022 | 04:22 PM
tabijan's Avatar
tabijan
Is there a part number for the nut plate that holds the corner lamp lower screw to the headlight bucket/header?
Sixto
07 E350 5.4 183K miles
Old Sep 20, 2022 | 04:06 AM
JWA's Avatar
JWA
Post a photo of the area or part if you can.
Old Sep 20, 2022 | 07:47 AM
manicmechanic007's Avatar
manicmechanic007
Are you talking about the J (or U) nut?
Old Sep 20, 2022 | 07:03 PM
tabijan's Avatar
tabijan
The PO must have taken the van jousting. There’s a dent below the replaced right corner lamp. The headlight header frame is broken where it holds the nut plate for the lower corner lamp screw. A header is $50 but I don’t feel like replacing it. I’m going to try filling the broken header flange with Plastic Weld. It would be nice to fit a nut plate but I could send the lower screw into the filler.
Upper nut plate in place, lower nut plate broken off -
Sixto
Old Sep 20, 2022 | 09:44 PM
manicmechanic007
I would go to the junkyard for a new headlight bucket
I don't believe that nut is available separately
Old Sep 20, 2022 | 11:10 PM
tabijan's Avatar
tabijan
I thought about that but am I saving much if a new one is $50? Junkyard one might have cracks or breaks or missing nut plates that I don’t notice until I install it.
Sixto
Old Sep 21, 2022 | 04:15 AM
JWA's Avatar
JWA
The fastener you have circled is pressed into the molded header panel and I've never seen them on any fastener/clip/retainer site I've visited. While its not the most fun job replacing the header might be the best bet for an overall high quality repair.
That would be my approach but as always YMMV.
Old Sep 21, 2022 | 02:07 PM
bold1's Avatar
bold1
Just screw a 90 degree angle bracket onto your broken tab and drill a screw hole in it.
Firewiz
2004 - 2008 F150
Mar 7, 2021 11:05 PM
vidaliaman
Jan 28, 2016 09:50 AM
C. Lee Colbert
1983 - 2012 Ranger & B-Series
Feb 6, 2011 08:54 PM
99f350sd
Aerostar
Mar 18, 2008 08:58 PM
