ZF6 issue
Old Oct 1, 2022 | 07:29 AM
  #31
dsrace's Avatar
dsrace
Originally Posted by ESwift
Test drive results- noise seems gone. Odd it sure sounded identical in sound and location to the failed throwout bearing last year. The bolt in the zf6 def threw me off, as did the metal flakes in the t case. Either way, I will take this easier and cheaper fix for this beat on plow truck. I will update if the noise returns upon more driving
on the 1995 2wd i had the u joints weren't that bad but were out of grease and starting to rust. they made all kinds of noise under the truck and felt solid when i checked them. i knew they were original with 140k on them so i replaced them and all noises went away. it got worse on the interstate vs 40 mph ish.
glad you found the problem and it wasn't a complete tear down or replacement of the trans!! that bolt you found is still crazy though!
rderrick121
37
Apr 14, 2022 08:13 AM
61Redneck
Sep 28, 2021 03:28 PM
Old51f3
Nov 19, 2019 10:31 AM
profro
Mar 15, 2013 10:27 AM
ccarrier
Apr 14, 2010 10:48 AM
