2002 Excursion V-10 stalls randomly
any ideas?
pumps on our rigs are notoriously poor, and prone to failure. What was the stealerships reason for thinking it was the battery causing the stalling?
Is the above statement about the dealer saying the computer shows good fuel pressure correct?
Our 2002 Excur has the fuel rail test port and I thought the fuel pressure wasn't available to the computer because there is no sensor for it.
Wasn't the test port deleted when the fuel rail pressure was available to the computer in later years?
i am having them put a new " fuse box " with a new relay in the vehicle. i am hoping this solves this issue. i will keep everyone posted
This is how I learned to 100% rule in or out a weak or intermittent fuel pump issue.
Step 1
Connect a mechanical fuel pressure gauge to the fuel rail, most of them still have one to my knowledge, and run the gauge to where you can see it while driving, and go for a drive doing some hard acceleration with high RPM and see if the pressure dips and falters and cannot maintain, or if that is impossible because your gauge has a short hose, put someone else in the driver seat, and have them bring the RPMs up to 4000+ and see if the pressure maintains, if the pressure remains good, go to step 2.
Step 2.
Assuming you were not able to detect any problems in step 1, and that your fuel pressure gauge won't easily reach where you can see it while driving, take the gauge and tool needed to connect it with you, and when the stall re-occurs, jump out and throw the gauge on and test it quickly.
My 07 GT's computer reported fuel pressure was always good, yet it would stumble, ping, and occasionally almost die under hard acceleration, and 3 different shops were baffled, including a reputable Ford Dealer, and it turns out it was not their fault they couldn't find it.
Under my own suspicions based on my understanding of the engine and fuel system, I decided to do my own tests, and i connected a fuel pressure gauge to the fuel rail, and ran the hose between the hood and wiper panel, and up to the windshield and propped it under the driver side windshield wiper so i could see the needle while driving.
Then I took the car out on the highway outside of town in the booneys, and i ran the **** out of it to get it nice and hot and warmed up completely, and did a U turn back the other direction Wide Open to the floor as i rolled through the gears, its a 5 speed manual, and when i got to third is started sputtering, pinged once or twice and i felt the pull power drop out as it did, but what i saw on the gauge told me why, the fuel pressure was wildly dropping, shooting back up, dropping for 2-3 seconds below 10 psi, then shooting back up to 40 PSI, then back down to zero, and shooting up to 30, it was all over the damn place, long story short, the pump was malfunctioning under high load, but only significantly once the car was fully, and i mean fully hot and under load, pulling lots of power.
I took it to the dealer because i didn't want to mess with dropping the tank, told them to replace the pump even though the computer says its fine, do it anyway essentially, problem vanished and has not been seen since, pumps don't always fail dead, sometimes they get dementia, or just sit there and have seizures randomly.....
Not sure if that is anything like what you are seeing happening, but thought it might help.
I've seen a spacer plate that goes under the regulator that provides a port for a gauge, but it's pricey.
