1987 Steering box upgrade?
Old Sep 18, 2022 | 10:34 PM
1918ALF's Avatar
1918ALF
Hello all, have a 1987 F-150 4.9 ZF Longbed. The power steering box is kaput after 460,000 miles. Junk right ? Lol 😂. Anyways was told years ago there was a better steering box to upgrade too, like off a 1 ton or something from Red Head? Been many years since I was told about it. Anyone have any suggestions about a steering box replacement that would be good to do? Oh, it’s a power steering box.
Thanks, Scott in Dallas
Old Sep 19, 2022 | 04:58 AM
2dwoods's Avatar
2dwoods
I put a red head in my 95 last year and steering is tight as new
Old Sep 19, 2022 | 06:20 AM
My4Fordtrucks's Avatar
My4Fordtrucks
If you look up the steering gear on RockAuto it is the same gear for Bronco and all the F-Series trucks. I buy Lares or Cardone remanufactured. I just put a Lares steering gear the Bronco II about a month ago. Very good so far. Some people like the Redhead or Blue Top boxes. I have no experience with them.
Old Sep 19, 2022 | 06:42 AM
JJF20's Avatar
JJF20
I prefer Blue Top. One nice thing, they replace the plain bearings (bushings) with roller bearings. They worked perfectly right out of the box. I have used Lares in the past as well, but prefer the blue top. Lares was very tight right out of the box, and a couple weeks later getting loose again.
Old Sep 19, 2022 | 07:09 AM
2dwoods's Avatar
2dwoods
yea thats same for red one new rollers instead of bushings
Old Sep 19, 2022 | 07:10 AM
2dwoods's Avatar
2dwoods
yea that's same for red one new rollers instead of bushings, opp's i did it again
Robfinger's Avatar
Robfinger
Look into the early SD boxes as well, OEM is ideal obviously. If your donor/application is 4x4 DRW truck you get larger output shaft which is nice but the pitman arm is longer and so only matching the D60s axles (and D50 monogram SD axle), but the rest of the trucks got boxes that will accept your factory pitman arm 👍 Take a look on the FSB site cause that's where I found info on this, they did explain what makes the SD boxes better than the older ones but it's been a while and I've forgotten so can't pass that knowledge here unfortunately.
Old Sep 19, 2022 | 08:20 AM
R&RFord's Avatar
R&RFord
I have been very happy with my RedHead. I did have to replace one seal after a few years of operation, but I have not noticed any slop creeping in yet. I also replaced the factory steering shaft with a Borgenson. These 2 changes eliminated all my steering slop. Replacing the TTB pivot bushings and the radius arm bushings greatly improved the steering stability/consistency especially at speed. It still does not drive like a modern vehicle, but it is now the best driving OBS Ford I have ever driven.
Old Sep 19, 2022 | 10:54 AM
SFaulken's Avatar
SFaulken
Having bought a number of them over the years, I'd not recommend BlueTop over RedHead, or vice versa. They're basically equal in my experience, I go with whichever has the box I need in stock at the time (RedHead typically gets the nod for me, as I can can just drive to their facility and get the new box and drop my core off, saving me having to deal with freight).
In general, FLAPS remans are minimum passable, any box you see from FLAPS that's sold as a *new* steering box, stay the hell away from, they're garbage.
Old Sep 19, 2022 | 11:34 AM
OBS460's Avatar
OBS460
The upgraded steering box someone told you about was most likely a Saginaw PS setup from an E-series van. You would need the steering gear box, high pressure lines and the bracket for the pump from the same engine unless the 4.9 shares brackets with the 5.0 or 5.8.
Old Sep 19, 2022 | 11:40 AM
SFaulken's Avatar
SFaulken
It does not. The 4.9 has it's own special bracket, for the saginaw swap.
Old Sep 19, 2022 | 01:01 PM
R&RFord's Avatar
R&RFord
The steering gear box is the same between the vans and trucks, it is the pump that is different. I've done this swap and the only advantage is the reduction in noise. Both style pumps provide adequate pressure.
Old Sep 19, 2022 | 01:06 PM
OBS460's Avatar
OBS460
the noise reduction and longevity. The truck pump is cheap and wears out under normal use and the Saginaw is superior design and proven to work longer.
Old Sep 20, 2022 | 01:02 PM
94Crimson's Avatar
94Crimson
The guy from Minute Masters on YouTube changed out his to one from an "E" model Ford van. You should look it up before you buy anything.
Old Sep 20, 2022 | 01:40 PM
My4Fordtrucks
The OP is in search of an upgraded steering gear. An E-Series van has the exact same gear as a full size truck. What is different on the vans is the power steering pump.
