Trailer Harness Question
Old Sep 18, 2022 | 11:47 AM
sohcmike's Avatar
sohcmike
4wd Low
Hey guys. Working on a 1996 F250. Someone took the factory trailer harness off my truck so i bought a harness from etrailer.com. I'm looking for a hot wire coming off the truck to connect to the black(hot) wire on the etrailer harness. Before I pull a new wire from the battery or fuse block, can anyone tell me what the big red wire and the big white wire are in this photo? I've got all the other stuff connected but I need the hot from the truck and curious about what these two are for. Thanks for your help.
Old Sep 18, 2022 | 11:51 AM
Hit Man X's Avatar
Hit Man X
Use a volt meter. Verify the fuses and relays are installed also.
Do you have an EVTM handy? I too had to fix the one on my 96 dually, easy.
Old Sep 18, 2022 | 11:53 AM
sohcmike's Avatar
sohcmike
4wd Low
I used both a volt meter and test light on those two and don't get anything.
Old Sep 18, 2022 | 11:56 AM
Hit Man X's Avatar
Hit Man X
And fuses plus relays? Without those, you will not have power there.
Old Sep 18, 2022 | 11:59 AM
sohcmike's Avatar
sohcmike
4wd Low
Ok thanks. That points me in a direction. Electrical is not my forte.
Old Sep 18, 2022 | 01:31 PM
Hit Man X's Avatar
Hit Man X
No worries, I am pretty good at it.
Always start with the easy stuff. I will not be home for a few weeks, but when I am I can snap pics of the EVTM for the wiring.
Old Sep 18, 2022 | 08:53 PM
sohcmike's Avatar
sohcmike
4wd Low
Thanks. The red wire is hot with the key on. I found a blown 30A fuse under the hood. Still don't know what the big white wire is but i have all the trailer harness connected so i'm good for the moment. Would like to look at the EVTM when you get back. Thanks again.
Old Sep 19, 2022 | 07:26 AM
Ratsnesthd's Avatar
Ratsnesthd
Big white wire is ground.
Old Sep 19, 2022 | 07:27 AM
Ratsnesthd's Avatar
Ratsnesthd
big white is ground.
Old Sep 19, 2022 | 07:28 AM
Ratsnesthd's Avatar
Ratsnesthd
Old Sep 19, 2022 | 07:31 AM
Ratsnesthd's Avatar
Ratsnesthd
hers is a diagram I had gotten off of here.
Old Sep 19, 2022 | 07:57 PM
sohcmike's Avatar
sohcmike
4wd Low
Old Sep 20, 2022 | 09:08 AM
Ratsnesthd's Avatar
Ratsnesthd
you are very welcome. Your big red wire is actually orange if you noticed In the wiring diagram. You should get it from here.
cbrown9064
Feb 2, 2021 10:31 AM
z 97ford1
1997 - 2003 F150
Feb 14, 2020 08:20 AM
Glockem45
All Things Towing
Dec 19, 2008 03:11 PM
ccrider966
All Things Towing
Sep 19, 2004 02:50 AM
jschira
All Things Towing
Jan 1, 2003 08:57 PM
