General Automotive Discussion
1990 F250
Old Sep 17, 2022 | 05:33 PM
2IndiansRlittle's Avatar
2IndiansRlittle
3rd Gear
Question 1990 F250
My truck cranks, but I have no power to the coil. Is there an inline fuse between the battery and the Ignition Coil ? If so, where will I find it ? The interior fuse box does not list any fuse for the Ignition Coil. I am unable to find any fuse box under the hood, and an earlier post stated that THERE IS NO fuse box under the hood.
Old Sep 18, 2022 | 07:24 AM
JWA's Avatar
JWA
You're measuring or testing for power at the coil with a light etc? Is the coil itself bad?
Old Sep 18, 2022 | 08:55 AM
2IndiansRlittle
3rd Gear
1990 F250
I figured that once I have power to the coil, I would know if the coil was good or bad. I used a test light on the wire to the coil. No light with the ignition on, nor while cranking.
Old Sep 18, 2022 | 09:36 AM
RLXXI's Avatar
RLXXI
Could be a bad ignition switch. Jumper the coil + terminal directly to the battery + terminal and see if it'll fire up.
Old Sep 19, 2022 | 12:25 AM
2IndiansRlittle
3rd Gear
I will try that, thanks. ( So if it fires up, it could be a bad ignition switch, or a short somewhere from battery to coil ? )
F250hd1997
Jan 30, 2018 10:36 AM
Troy77+79
Mar 9, 2011 10:24 PM
dustys7.3psd
17
Jan 9, 2010 11:35 AM
mltdwn12
Apr 25, 2006 01:10 PM
renchr56
Feb 22, 2006 04:39 AM
