Speedometer/Odometer Failure
Old Sep 17, 2022 | 10:26 AM
R&RFord's Avatar
R&RFord
My speedometer/odometer went dead last night after passing over a rough bit of road and then came back a mile or so later during a hard manual shift. No other systems went down, so I presume it is something specific to the PSOM. Looking around it is most likely a problem with the 296 Hot in Run circuit or something on the PSOM board itself...
Is there anything else I should be looking at, common failures?
Thanks!
Old Sep 17, 2022 | 11:49 AM
OBS460's Avatar
OBS460
Check the speed sensor in the rear axle. If it goes so does your speedo. Its only 1 bolt to replace but they have an O-ring so you might want a flathead screw driver to pop it out.
Old Sep 17, 2022 | 11:56 AM
R&RFord's Avatar
R&RFord
I see how a drop in VSS will kill the speedometer but not the odometer.
Old Sep 17, 2022 | 12:06 PM
OBS460's Avatar
OBS460
Then don't check it.
Old Sep 17, 2022 | 12:21 PM
Prototypemech's Avatar
Prototypemech
Your vss is fine. You have a power/ground issue. Check your fuses. Sometimes, just removing them and plugging them back in is enough to make good contact and keep ya going.
Old Sep 17, 2022 | 12:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The speedo and odo get their reading from the VSS. If the VSS doesn't work, neither does the speedo or the odo.
Old Sep 17, 2022 | 12:41 PM
Prototypemech
Mark, I believe the OP is stating that his odometer blanked out, as if it wasn't getting power.
Old Sep 17, 2022 | 12:51 PM
R&RFord's Avatar
R&RFord
Correct, the display was blank.
Old Sep 17, 2022 | 12:53 PM
sandymane's Avatar
sandymane
Yes but he said it is working now. Perhaps the VSS could have had some tone ring shavings that effected it?
Old Sep 17, 2022 | 12:57 PM
R&RFord's Avatar
R&RFord
I realize that the odometer will no longer move forward without VSS but it would still display the last known mileage, correct?
Old Sep 17, 2022 | 02:00 PM
Mark Kovalsky
Yes, you are correct. Sometimes I am following too many conversations and lose details such as this. Sorry!
Old Sep 17, 2022 | 03:00 PM
R&RFord's Avatar
R&RFord
I have driven the truck over the bumpiest roads I could find nearby in an effort to re-create the problem without success. I also had no success wiggling wires that I could get to under the dash. I have not yet, but will pull and inspect both fuses.
Old Sep 18, 2022 | 07:28 AM
buddy119's Avatar
buddy119
Mine died a couple of years ago. I had to send it out to be rebuilt. If I remember correctly, it's like the PCM in that there's a capacitor or something that corrodes and pukes all over the board.
I sent mine to these guys: https://modulemechanics.com/product/...epair-service/
Old Oct 14, 2022 | 07:54 PM
Norcal01's Avatar
Norcal01
5th Gear
I have a '92 F150 Flairside 5.8 4X4, that had the same issue, took it to the dealer & hundreds of dollars later told me it needed a new instrument cluster that was special order, took it to a shop suggested by the transmission shop that rebuilt the transmission, 1 hour of shop time traced it the speed sensor, problem solved.
Old Oct 14, 2022 | 08:26 PM
Prototypemech
Speed sensor won't cause the odo to blank-out. That's a power issue.
