Bad battery drain
Old Sep 16, 2022 | 05:13 PM
95% stock's Avatar
95% stock
Bad battery drain
Hello people,
My F350 has a really bad battery drain, i measured the parasitic draw on each positive wire, all are acceptable except for one, and that one is bad
It is the engine harness that connects to the passenger side battery, and BAD means a draw of 0.6 amps, which is considerably more than what is good
I know what you are saying, it's the alternator. But why, why could it be so easy/
And yes it's become really interesting, the alternator has a 0.1 amp draw, which is not ideal but ok. Where's the 0.5 amp draw?
Yes, i need help
I disconnected the alt. and the draw was still there, but 0.1 amps less, 0.5 amps
I also disconnected the GPCM and the IDM, then from the PCM, no change whatsoever. I tried to do both connectors below the P.S. reservoir but it was quite tough and realized that it wouldn't have been worth
I thought that it is connected to other things but after a quick review of the wiring diagrams it didn't appear to, not even the control units previously mentioned
Is it actually connected to something else? Any ideas on what could cause this?
Old Sep 16, 2022 | 06:18 PM
xcrsp440's Avatar
xcrsp440
How about setting up your meter, then start pulling fuses. One by one check the readings after you remove each fuse. When you get a change check what is connected to that circuit.
Old Sep 16, 2022 | 08:01 PM
95% stock's Avatar
95% stock
It's not the other crap, it is in the engine circuit, no fuses
Old Sep 16, 2022 | 08:52 PM
bismic's Avatar
bismic
The v-reference circuits (critical engine sensors) are powered out of the PCM. The PCM fuse is F2.22. That is ONE of the critical engine circuits. This fuse also services critical 12V actuators. I would at LEAST try to see what happened with that one disconnected.
Old Sep 25, 2022 | 11:58 AM
95% stock's Avatar
95% stock
Thank y'all for helping. But i found the issue, the alternator is the cause of the .5 amp drain. New alternator time it is
Old Sep 25, 2022 | 01:18 PM
bismic's Avatar
bismic
Originally Posted by 95% stock
Hello people,
Yes, i need help
What happened in the measurement (in bold) above?
Old Oct 23, 2022 | 06:30 PM
95% stock's Avatar
95% stock
I have been offline for a long time
The drain is through the alternator exciter wire, when I unplug the alternator connector and it has normal draw, but when it is plugged again, it is very high
What alternator brand should I get?
Old Oct 23, 2022 | 06:40 PM
TooManyToys.'s Avatar
TooManyToys.
So your saying the I circuit always has 12v? If that’s so, it’s not an alternator issue. The I circuit should be at 0v when the key is off.
If there is 0v on I when the key is off, then you do have an issue with the alternator regulator, it’s feeding the sense A circuit into the I circuit.
Old Oct 24, 2022 | 02:34 PM
95% stock's Avatar
95% stock
My truck is at the body shop, so I can't test it but iirc it had 12 volts with the key off
What could be the issue if that's the case?
My truck may be back on Friday
Old Oct 24, 2022 | 02:55 PM
TooManyToys.
Gauge cluster problem or PCM problem. It's rare to have a PCM issue on these trucks.
File Type: pdf
Old Oct 24, 2022 | 03:08 PM
TooManyToys.
Some more for you.
File Type: pdf
File Type: pdf
File Type: pdf
T diesel
Aug 29, 2020 02:28 PM
1984fordf150
Apr 28, 2012 02:32 AM
GoneFishen
Jun 14, 2010 08:14 PM
fhf3723
Sep 21, 2005 11:39 PM
fordtruckman1
Electrical Systems/Wiring
Jan 30, 2005 03:41 PM
