Building Materials
Old Sep 15, 2022 | 01:16 PM
DAV1972's Avatar
DAV1972
Building Materials
I am needing to move some pallets of bagged concrete and CMU block in my 1968 F250. The weight should be just over 3,000 pounds a pallet.
This won't overload the truck right? Anyone with experience please chime in.
Old Sep 15, 2022 | 01:33 PM
'65Ford's Avatar
'65Ford
I'd load it into my '65 F250 and not think twice. I've got good tires, brakes, and completely redid the suspension front and rear. Plus no frame rust.
Old Sep 15, 2022 | 02:13 PM
DAV1972's Avatar
DAV1972
Thanks!....Just what I wanted for some peace of mind. I had not put a load in this truck before. Tires and brakes good.
Old Sep 15, 2022 | 02:33 PM
Eric Hamilton's Avatar
Eric Hamilton
DAVI1972, I would load it and check that the leaf springs aren't bottomed out on the stops before driving away. Also, loading over the axle is always ideal. I hauled 1,500 lbs. of scrap steel once and my truck was barely squatting...it also has extra set of leaf springs from the factory since it's a Camper Special. When it's not loaded down....LOG WAGON.
Old Sep 15, 2022 | 02:34 PM
'65Ford's Avatar
'65Ford
Might check the door tag to see what your GVWR is and weigh your truck empty to see how much payload you should have. I don't know about '68 pickups but the '65 F250 had three choices in rear leaf springs. I bought new the heaviest set and have the camper special helper springs on top.
Old Sep 21, 2022 | 08:11 PM
DAV1972's Avatar
DAV1972
Fyi.....I hauled a pallet of CMU block today. The bed was squashed down a bit as well as the tires but it did get it home. Weight of the block was about 3,125 pounds. Truck was definitely overloaded but got the job done.
Old Sep 21, 2022 | 10:10 PM
1TonBasecamp's Avatar
1TonBasecamp
I don’t know what air pressure you normally keep in your rear tires, but when you’re getting ready to haul a big load make sure you inflate them to a safe level.
Obviously you don’t normally need the maximum pressure when you’re running around empty all the time. But add 3000 pounds of load to the back, and your tires will thank you for pumping them up.
Perhaps all the way to their maximum operating pressure.
Depends on the tires, so you might just read the inflation and weight capacity specifications on the sidewall.
Old Sep 22, 2022 | 02:50 PM
DAV1972's Avatar
DAV1972
Good call on the tire pressure! I checked the pressure this morning and had 50 psi. I inflated them to 80 psi and picked up my second pallet. I noticed very little squishing of the tires and it drove much better!
Old Sep 22, 2022 | 04:26 PM
1TonBasecamp
Excellent!
Yeah, it’s all part of the weight carrying package.
Spring rate, axle size, brake size, gear ratios, and almost the most important of all (especially for safety reasons) tire ratings and pressure.
Glad to hear that it made a noticeable difference in your handling manners.
Old Sep 25, 2022 | 08:52 PM
Alex from GA's Avatar
Alex from GA
I used to get mulch loaded in my '68 Camper Special with 12.50x33 tires and the tires hit the fenders on bumps. It was fine with a 12' overhead camper so I probably had 4000 lbs worth of wet mulch in the bed. I'd hate to take a long trip with that load.
Old Sep 25, 2022 | 11:05 PM
1TonBasecamp
Yeah, I think those wheelbearings would’ve protested the journey!
c249a
Dec 7, 2013 10:23 AM
Marc150
General Automotive Discussion
15
May 2, 2010 05:07 PM
DR Smith
Nov 5, 2007 09:36 PM
ferguson777
Apr 9, 2004 09:21 AM
stryder
Feb 21, 2003 08:30 PM
