7.3 reliability
Old Dec 18, 2022 | 10:48 AM
  #91
FishOnOne's Avatar
FishOnOne
Originally Posted by d7velo1
I've been watching for reports of issues since it's 2020 release.
1. Initially (2020) there was the ignition coil wire issue. Ford redesigned the ignition coil wires. Problem solved.
2. I've read about a couple lifter failures. Doesn't seem to be a wide spread issue at all. Like I've only read about 2 or three reports of this issue (2020-2022)
3. One report about a front crank seal leak.
I'm sure there are some other examples people can find out there. I'd love to know how many 7.3L have been sold since 2020?
I'm convinced the 7.3L is a very very reliable, solid motor. Ford designed it old school, solid, beefy and simple. Port injection, push rod, 6 bolt mains, iron block, over sized skirt, over-sized head bolts, forged crank, chain driven oil pump.
The only thing I don't "like" about the design is the seemingly lack of iron between cylinders...small head gasket sealing surface (due to the coolant slits). BUT, there have been zero reports of head gasket failures. Those coolant channel slits are there to carry away heat between cylinders. Heat is a head gaskets worst enemy...so real world performance is proving the design is working in the 7.3L's naturally aspirated application.
I'm loving my 7.3L...only 6,200 miles so far (daily driver), but absolutely 100% glad I chose the Godzilla for my Super Duty. No weird noises, nothing.
My 2018 5.0L F-150 had an annoying 'throttle off' chain rattle when cold. Very common. Had since day 1.
My 5.0L also had a VCT solenoid failure at 60,000 miles. Fairly common as well. Not hating on the Coyote...very very good motor overall. I've owned two (2nd Gen Coyote in Mustang GT) and the 3rd generation in the F-150. I'd buy another 5.0L no question.... So fun to beat 6.2L Camaros and 6.4L Challengers with a 5.0L Mustang (Go Ford) 😀
I'm hearing nothing about 'common' Godzilla issues. Nothing.
Can't say that about the 6.7L Powerstroke (as good as that motor is).
Things I've read about concerning 6.7L issues:
* Upper oil pan leaks ($)
* Radiator Coolant Leaks
* Turbocharger failures ($)
* DEF tank issues / sensor issues
* HPFP failures ($)
* EGT Sensor Failures
* EGR Cooler Clogging ($)
Been more than a couple of lifter failures reported on FTE:
munson
grumblin
Pamcakes
Louisville Joe
Robin
Dig4it - also reported 8 more were at repair shop
springhook
And some of these people reported there's failures occurring in the motorhome application.
Been more than one reported about front main seal leaks on FTE:
Rain Desert
scraprat- who's participating in this thread but didn't report his problem.
Jay Carver
bowsniper
Hartford 8018
Hopefully I get the visit with my old cousin this Christmas who's been a Ford master tech for many years to get an update on what's he's seeing at the Ford shop.
Old Dec 18, 2022 | 10:52 AM
  #92
zeroo's Avatar
zeroo
Some math based on my current local fuel prices.
50000 miles/16.5mpg = 3030gal x $4.60 = $13939
50000 miles/13.2mpg = 3787gal x $2.60 = $9848
$4000 difference. As of now to be even diesel needs to be $3.25gal, but I’m sure gas will drop to as fuel comes down. I know maintenance is a little higher but it’s marginal. $4k is not enough really for me to dump my truck, BUT, my truck is still pulling a premium used price. I have $2k ford buck and 160k ford points. If i found a dealer that would xplan on a sitting 7.3 xlt I might do it for a year or so wile we go through economic pain next year and order a new 2024 or 2025. Its a thought because i think used prices will tank by spring as sales slump.
Old Dec 18, 2022 | 10:53 AM
  #93
scraprat's Avatar
scraprat
Top Answer: 5
Originally Posted by zeroo
I see you have the 3.73. Also what’s with the engine light? Just where truck isn’t started?
Yes, just turned key didn't start engine.
Old Dec 18, 2022 | 11:01 AM
  #94
OBS460's Avatar
OBS460
munson
grumblin
Pamcakes
Louisville Joe
Robin
springhook
Rain Desert
Jay Carver
bowsniper
Hartford 8018
My 460 has had a front main seal leak since it had 64,000 miles on it and I've done nothing for the last 50k miles but check the oil and it is always in the cross hatch. A front main seal leak is hardly a failure.
Old Dec 18, 2022 | 11:43 AM
  #95
scraprat's Avatar
scraprat
Top Answer: 5
Agreed, I believe there was just a bad batch of seals.
Old Dec 18, 2022 | 12:19 PM
  #96
FishOnOne's Avatar
FishOnOne
Originally Posted by kshoop1958
I'm crossing my fingers and hoping this 7.3 gasser turns out to be another legendary engine for Ford, similar to the 7.3 diesel.
I hope it turns out to be a great engine as well, but it's too early to tell and Fords recent engine designs and quality problems sure isn't confident inspiring.
Old Dec 18, 2022 | 01:19 PM
  #97
bigwin56f100's Avatar
bigwin56f100
thats what's wrong with forums is you only hear of problems. There are thousands of others who are trouble free
I'm from a 5.4 with zero problems other than exhaust manifolds. I'm one of the thousands that haven't had a problem.
you can pull all the history of .0005% of unhappy 7.3 owners I believe you'll find happy campers otherwise. And if you are thinking maybe you shouldn't get a 7.3, get a 6.7 what a great idea lol
markkevin
Maryland Chapter
Aug 2, 2024 06:17 PM
74dentside
Mar 25, 2022 02:17 AM
Everlanders
Aug 13, 2018 02:30 PM
swaybar
Apr 6, 2008 07:35 PM
