Intake venturi effect tubes...
Old Jul 6, 1999 | 07:21 AM
Deen Hylton
Guest
Posts: n/a
After reading all the dialogue about the "venturi effect tubes" from a couple of weeks ago...I located them on my 1989 460 and cut them off. I immediatly realized 5 MPH increase and an additional 300 RPM when towing my 9,000 lb. load over the mountains. Way to go Guys/Gals! Deen
Old Aug 22, 1999 | 05:11 PM
Guest
Posts: n/a
Old Aug 22, 1999 | 08:20 PM
mandm's Avatar
mandm
Deen,
I too, have an '89 F250 w/ 460. I'll have to look further for the discussion you mentioned. Are you talking about the venturi's in the intake air hoses? I pulled my hoses today, to gain better access to my air conditioner compressor, and saw them. Thought about pulling them out, except the idle air bypass hose is right there and I didn't want to screw up the idle system. Are we talking about the same "venturi's"? If so, why are they there in the first place, and how'd you remove them?
Thanks,
Dave
Old Aug 23, 1999 | 06:19 AM
Deen
Guest
Posts: n/a
Yes, they are the ones. I have not experienced any bad side effects (2,000 miles later). Use a hacksaw to cut them off (after removing unit from vehicle), make sure you file the edges to smooth air flow and then re-install...that's all there is to it. Deen
Old Aug 23, 1999 | 07:30 AM
mandm's Avatar
mandm
Any idea what these tubes are actually supposed to do? Maybe they're just some sort of intake noise silencer??
I'm not real concerned about the 'negative' affects of cutting them off, as there's tons of 'em in the junk yards.
How far back was the discussion on this.. I looked back a few pages, but didn't see it. Like to read up a little more before modifying.
Thanks,
Dave
Old Aug 24, 1999 | 11:36 AM
Mike and Susan
Guest
Posts: n/a
>Guys/Gals! Deen
I went back thru page 8 on the discussion list and could not find the dialogue about the venturi effect tubes either. I tried a search, but it only pulled up these threads. Deen---could ya point us in a direction on this? Thanks. Mike has got his hack saw out and ready!
Old Aug 24, 1999 | 12:21 PM
hoss's Avatar
hoss
73Galaxie
Aug 14, 2022 02:17 PM
drewduncan15
Feb 1, 2020 06:24 PM
phoskins
1983 - 2012 Ranger & B-Series
Mar 17, 2017 11:53 AM
dgoodman
Jun 6, 2014 04:19 PM
DeenHylton
May 2, 2001 10:29 AM
