Intermittent No Start
Old Sep 9, 2022 | 11:00 AM
bass-n-fire's Avatar
bass-n-fire
I have had a strange thing happen twice now. I drive my truck daily, at least a couple hours a day. Recently, I would get into my truck in the morning, and it acted like the batteries were dead. Turn the key, and the truck would "attempt" to turn over, but wouldn't do it. The first time, I figured well the batteries are bad. Had a buddy of mine give me a jump. When the cables were connected, I didn't even give it 30 seconds before I tried to start it. It started like there was no issue. Had the batteries tested ( still connected to the truck) and they tested good. Drove the truck for a couple of weeks with zero issues. This morning, the same scenario. As soon as the cables were connected, truck started right up. This time, I noticed that the fuel gauge read empty for a few minutes, then gradually caught up.
The second issue, could be completely unrelated. Over the past month or so, I have noticed that occasionally the steering wheel controls would not operate correctly. Example, menu up button operated as the OK button, volume up button would change the mode of the radio. This is also intermittent.
Does anyone have experience with these issues? I also posted this question in the Super Duty Forum
BTW, my truck is 2017 F350 diesel, 4x4, CCLB
Old Sep 9, 2022 | 12:27 PM
helifixer's Avatar
helifixer
I believe there is a low voltage safety in these trucks, ie. below X volts it won't let the truck start. put a start pack or jump it and the computer sees over X volts and lets it start.
I may be totally wrong about that though, either way I don't own a diesel truck with batteries that are over 3 years old, at 3 years they get replaced regardless of condition. cheap insurance in my opinion.
Old Sep 9, 2022 | 03:30 PM
Dirthawg2.0's Avatar
Dirthawg2.0
Each battery needs to be tested independently as they are connected in parallel. If either battery is low and needs to be replaced, it's recommended to replace them in pairs.
Old Sep 9, 2022 | 03:51 PM
bass-n-fire
Thanks for the replies. I’ll stop on my way home from work tomorrow and get the batteries load tested. Then go from there.
Old Sep 11, 2022 | 07:05 AM
senix's Avatar
senix
load test them disconnected so there is no draw from the other battery.
I would also be inclined to crawl under the truck and check the wiring harness that runs under the cross member. Check it for chafing.
bass-n-fire
Sep 9, 2022 03:49 PM
Torqd1
May 30, 2020 05:50 PM
bluwaterbrew
6.7L Power Stroke Diesel
15
Sep 18, 2019 09:24 AM
Shanef1501176
2009 - 2014 F150
Oct 16, 2017 09:54 PM
Scruffy
Feb 8, 2007 08:42 AM
