My 99 7.3 Zf6 4x4
#46
#47
The following users liked this post:
#48
#50
#51
Got a hydra and put it on today and finally made it into the 20th century tuning. Replaced the ol trusty ts6 that's been. In there for 10 years. lol I just mounted it over the hole for the ts6 ****. I'll be doing a dash swap sometime and mount it better.
Got a cheap set of running boards off Facebook marketplace. Not sure if I'll leave them on or not but I'll give them a go.
The following 3 users liked this post by Tpayne621:
#52
Jeff
#53
The following 2 users liked this post by Tpayne621:
#54
#55
#56
If it's a "Champion", many people had great luck with their product, however I was not one of them. Bought one and the cores separated from the tank, they replaced it thru warranty and same thing happened again. They gave me a 100% refund on the original purchase price however I lost every dollar spent for coolant (well over $100.00) + cleaning up the huge mess under the hood two times. Lucky there was no permanent engine damage. I went back to stock rad and that was years ago.......
#57
#58
#59
Weather was nice today so got a little bit done. Swapped in that radiator to give it a try. I'll keep the one I took out for a while and make sure everything is good with it. So far it seems fine in a short drive to get everything hot.
Swapped in a riff raff thermostat housing I've had for a month or 2 I scored off marketplace for $20. Just had to get some bolts for it.
Radiator installed.
Rough Country dual steering stabilizer installed.
Radiator installed.
The following 4 users liked this post by Tpayne621:
#60
Put a 05 front end on it this past weekend. Some new headlights with projectors and separate high low bulbs with led bulbs installed. 20 inch light bar with day time running light built into it in the bumper. Also installed a set of factory cab lights with factory wiring with just led bulbs and smoked lens. Also swapped on a new Motorcraft belt tensioner and threw old one in the toolbox for a spare. Also swapped in some different lights into the headache rack I put on. The have running and brake lights around the outside and centers light up white with reverse.
