My 99 7.3 Zf6 4x4
  #46
Old 11-02-2022, 04:35 PM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is online now
Its Comin Right for us!
Received 1,481 Likes on 964 Posts
Nice!!! And yes that Boot resulted in some cut up hands and tools thrown around the shop.
  #47
Old 11-02-2022, 04:38 PM
Tpayne621's Avatar
Tpayne621
Tpayne621 is offline
Received 1,150 Likes on 740 Posts
Hopefully the people that already bought a turbo can get a little discount on them. But I agree. There doing great things with these old dinosaurs.
The following users liked this post:
  #48
Old 11-02-2022, 05:22 PM
ESwift's Avatar
ESwift
ESwift is online now
cncfab
Received 1,668 Likes on 986 Posts
I had to trim my boot a little, I also heated/warmed it slightly and used dawn soap and it installed easier.
  #49
Old 11-02-2022, 05:26 PM
Tpayne621's Avatar
Tpayne621
Had to trim mine also.
  #50
Old 11-03-2022, 08:12 AM
KubotaOrange76
I trimmed mine too much, used dawn soap and wound up slipping and cutting my hands/jamming fingernails on the compressor housing pushing so hard.
Charlie sent me picture of the prototype boot, looks to be built very similar to the oem rubber style.
  #51
Old 11-28-2022, 04:29 PM
Tpayne621's Avatar
Tpayne621
Got a hydra and put it on today and finally made it into the 20th century tuning. Replaced the ol trusty ts6 that's been. In there for 10 years. lol I just mounted it over the hole for the ts6 ****. I'll be doing a dash swap sometime and mount it better.
Got a cheap set of running boards off Facebook marketplace. Not sure if I'll leave them on or not but I'll give them a go.
The following 3 users liked this post by Tpayne621:
  #52
Old 12-01-2022, 05:22 AM
jeffchap6's Avatar
jeffchap6
jeffchap6 is offline
Truck looks badass man. I like the wheels!
Jeff
  #53
Old 01-11-2023, 04:47 PM
Tpayne621's Avatar
Tpayne621
Picked up a headache rack off marketplace for a deal. Cut the bars out of the center section where the slider window is. Got it put on and wired up the lights today.
The following 2 users liked this post by Tpayne621:
  #54
Old 01-12-2023, 04:34 PM
Tpayne621's Avatar
Tpayne621
Picked this up today for $100. Never been used. 3 row all aluminum radiator. It one of the cheaper ones not no mishimoto $$$. Not sure if I want to try and run it or just resale it. I'll probably atleast give it a try.
  #55
Old 01-12-2023, 04:58 PM
Sous's Avatar
Sous
Sous is online now
Received 4,546 Likes on 2,884 Posts
Nice find! Plenty of people on here are running the cheaper radiators like that. Sure is shiny.
  #56
Old 01-13-2023, 07:18 AM
catbird7's Avatar
catbird7
catbird7 is offline
If it's a "Champion", many people had great luck with their product, however I was not one of them. Bought one and the cores separated from the tank, they replaced it thru warranty and same thing happened again. They gave me a 100% refund on the original purchase price however I lost every dollar spent for coolant (well over $100.00) + cleaning up the huge mess under the hood two times. Lucky there was no permanent engine damage. I went back to stock rad and that was years ago.......
  #57
Old 01-13-2023, 07:37 AM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is online now
Before I retired, I owned an auto repair shop and found that the only radiators that last these days are the factory style ones with the plastic end caps. The metal end caps have to deal with so much thermal cycling that they end up cracking. Hot at one end and cold at the other is hard on metal. I would sell that radiator and use the money towards a Motorcraft or equivalent one of good construction. My 23 year old 1999.5 is still running the factory radiator with no signs of failing, yet. (Knock on wood). If it gives up, I'll purchase and install the real deal again.
  #58
Old 01-14-2023, 04:02 PM
Tpayne621's Avatar
Tpayne621
Marketplace local find of the day. Rough Country dual stabilizer kit new in box. Picked it up for $60 maybe it will warm up some tomorrow and I'll throw it on.
  #59
Old 01-15-2023, 04:54 PM
Tpayne621's Avatar
Tpayne621
Weather was nice today so got a little bit done. Swapped in that radiator to give it a try. I'll keep the one I took out for a while and make sure everything is good with it. So far it seems fine in a short drive to get everything hot.
Swapped in a riff raff thermostat housing I've had for a month or 2 I scored off marketplace for $20. Just had to get some bolts for it.
Radiator installed.
Rough Country dual steering stabilizer installed.
The following 4 users liked this post by Tpayne621:
  #60
Old 02-13-2023, 04:52 PM
Tpayne621's Avatar
Tpayne621
Put a 05 front end on it this past weekend. Some new headlights with projectors and separate high low bulbs with led bulbs installed. 20 inch light bar with day time running light built into it in the bumper. Also installed a set of factory cab lights with factory wiring with just led bulbs and smoked lens. Also swapped on a new Motorcraft belt tensioner and threw old one in the toolbox for a spare. Also swapped in some different lights into the headache rack I put on. The have running and brake lights around the outside and centers light up white with reverse.
Quick Reply: My 99 7.3 Zf6 4x4
