rack and pinion steering
Old Sep 5, 2022 | 08:38 PM
dremtofford's Avatar
dremtofford
for a 1988 f150 is it possible? worth it?
Old Sep 5, 2022 | 08:52 PM
SFaulken's Avatar
SFaulken
Anything is possible, with enough time, money, and trial and error.
Is it something you can just buy bolt on? No.
The Twin I-Beam or TTB setups do not lend themselves to easy adaptation of a Rack and Pinion setup.
Old Sep 5, 2022 | 09:37 PM
Scndsin's Avatar
Scndsin
Well there is a CV kit. Member did it on a lightning, Nice stuff, not cheap & well constructed.
Found it:
https://www.ford-trucks.com/forums/1...c-install.html
Old Sep 6, 2022 | 06:26 AM
arse_sidewards's Avatar
arse_sidewards
Let's say you stick a rack up in there. How's the geometry gonna work out? Ok, so you gotta have the links basically crisscross themselves in order to get it right. Congratulations, you've just invented the "swingset" that all the desert racers have been using for 40yr.
You'd be better off just building a swingset and using a modern steering box that has less slop to begin with and is 30yr newer to push it around.
lomesome1
May 17, 2021 09:19 PM
Kelyn Brown
Jul 19, 2016 11:52 AM
78F150classic
22
Nov 26, 2009 07:32 AM
Voodoo66
Aug 23, 2008 05:49 PM
