Code 212
Old Jun 19, 2022 | 06:32 PM
blacklab1's Avatar
blacklab1
Code 212
Time to break down and ask for some help. I've got a 97 f-250 HD with a 5.8. that I haven't owned long.
Starts fine idles fine, runs good till I put it under load. Then no power and crapping out.
Cap, rotor and plugs are new.
I'm getting code 212.
What is the quick fix? I have limited diagnostic tools.
Old Jun 19, 2022 | 08:46 PM
Mudsport96's Avatar
Mudsport96
Has it done this the entire time you've owned the truck since you say you haven't had it long?
Is the spout connector in place?
Old Jun 19, 2022 | 09:03 PM
blacklab1's Avatar
blacklab1
Yes it is.
Old Jun 19, 2022 | 09:11 PM
Mudsport96's Avatar
Mudsport96
Ok well 213 is Tach, circuit, SPOUT grounded. SPOUT circuit, open circuit. So you need to check the wiring in the spout connector and wires.
Old Jun 20, 2022 | 07:57 AM
Scndsin's Avatar
Scndsin
212 is what you get with wrong ICM also.
Do you have a grey or black module & if it is black, is it a Motorcraft module or aftermarket?
Old Jun 21, 2022 | 08:16 AM
blacklab1's Avatar
blacklab1
Will a truck run with a bad ICM?
Mine runs and drives just craps out under load.
Old Jun 21, 2022 | 09:18 AM
rla2005's Avatar
rla2005
Many times yes it will, but run like crap. Having the wrong ICM can mimic the same thing.
Old Jun 21, 2022 | 11:15 AM
blacklab1's Avatar
blacklab1
I swapped the ICM (grey one) out of my 95 that runs fine. Got same issues with same code.
Local parts guy says its IAC, Possible? or a wild guess?
Old Jun 21, 2022 | 11:45 AM
rla2005's Avatar
rla2005
You need a black ICM for a 1995 and a 1997 model year F-series gas engine truck(actually 1994 and later all require a black CCD Ignition ICM). Many part manuals are wrong including Ford. Code 212 is stored in Continuous Memory so you need to clear the codes after repairing or replacing a part. The alternative is going through 40 or so drive cycles for the computer to clear the Stored Code.
Once you have the correct ICM installed if you have the same "no power and crapping out" under load issue then check the fuel pressure.
Old Jun 22, 2022 | 09:17 PM
blacklab1's Avatar
blacklab1
Nice new black ICM, 180 bucks (small town Canadian best price).
No 212 code but still runs like cr--p.
Old Jun 23, 2022 | 08:29 AM
Ratsnesthd's Avatar
Ratsnesthd
so you say you bought a new black icm? Was it motorcraft or after market. ? Aftermarket’s are junk. I went through this on my 96. If in fact you did use oem and nothing has changed I’d check fuel pressure at the rail under the hood. Pull your vacuum line on the fuel pressure module and make sure no gas is coming out of it.
Old Jun 24, 2022 | 12:22 PM
blacklab1's Avatar
blacklab1
No more codes.
Test drive this morning, when cold it runs great. As soon as it warms up starts loosing power and craps out.
Old Jun 24, 2022 | 01:53 PM
rla2005's Avatar
rla2005
Please define "starts loosing power and craps out".
Old Jun 25, 2022 | 08:32 AM
Scndsin's Avatar
Scndsin
.... As soon as it warms up starts loosing power and craps out.
Your next recommended step was listed earlier:
Originally Posted by rla2005
....Once you have the correct ICM installed if you have the same "no power and crapping out" under load issue then check the fuel pressure.
Old Jun 25, 2022 | 08:36 AM
blacklab1's Avatar
blacklab1
A lesson learned, (AGAIN) never forget the obvious.
After chasing issues for another day, I decided to go back to basics. The only ignition parts I hadn't changed were the plug wires.
New wires end of problem. I hope. np more codes and runs better
