Ball Joints
Old Nov 11, 2003 | 11:50 AM
scooter_1968's Avatar
scooter_1968
Question Ball Joints
How Hard is it to replace the upper and lower ball Joints on a
93 F150
5.0 automatic
ext cab. 2wd
Old Nov 12, 2003 | 04:19 AM
missouguy's Avatar
missouguy
My '94 F-250 was a piece of cake. Just get the ball joint seperator and ball joint press from the auto parts store. Makes it a no brainer. I got mine at Autozone, rented me the tools for free.
Also get a Haynes manual, about 12 bucks.
Good Luck
Frank
Old Nov 12, 2003 | 06:06 AM
robraz's Avatar
robraz
piece of cake
i did mine without a seperator
just smash them out
1.5 hrs for both sides even if you don't know what you are doing
Old Nov 12, 2003 | 01:47 PM
dbuck50's Avatar
dbuck50
robraz, did you need the ball joint press?
Old Nov 12, 2003 | 01:57 PM
robraz's Avatar
robraz
nope-they came out easy with a little persuasion from a 2 lb sledge
took a 1 minutes to break them loose
use a socket and a hammer-no problem
Old Nov 12, 2003 | 03:25 PM
dbuck50's Avatar
dbuck50
is the procedure any more difficult on a 4X4?
Old Nov 12, 2003 | 04:25 PM
robraz's Avatar
robraz
it was done on a 4x4
no problem
Old Nov 12, 2003 | 05:18 PM
dbuck50's Avatar
dbuck50
did you have to pull off the tie rod and radius arm like the haynes manual says? I think it says you have to take the brake caliper and hub off and spindle...is this not necessary?
Old Nov 13, 2003 | 05:43 AM
robraz's Avatar
robraz
i don't know how you would remove the spindle without removing all the other parts you mentioned BUT if you are able to-please let me know-this may be a time saver for me
Old Nov 14, 2003 | 04:36 AM
missouguy's Avatar
missouguy
I just hate beating on my truck like that when the tools to do the job are available without charge. You have to go get the parts anyway, why not pick up the tools at the same time. I'd sure hate to damage my spindle or axle.
Just my .02
Frank
Old Nov 14, 2003 | 05:54 AM
robraz's Avatar
robraz
i agree-if the tools are available-definitely
but in my case they were not and the job was easy
and btw, i have acquired the tool and will use it next time
