Oil capacity
Old Sep 5, 2022 | 01:16 PM
timlange's Avatar
timlange
Oil capacity
I’ve been curious why my 94 takes less oil than my 97 when doing oil changes. I have not found any information of different capacities through different years. Finally put the two dipsticks next together and they are definitely different. They are the same length but the full indication are different. Any thoughts ?
Old Sep 5, 2022 | 01:57 PM
BuddyBarnes's Avatar
BuddyBarnes
94.5 takes 15 qt. I put 16 in and call it good. Someone change dip stick?
Old Sep 5, 2022 | 02:14 PM
timlange's Avatar
timlange
My 97 seems to take 14.5quarts to be right on the full line. When just dropping the oil in the pan and filter.. my 94.5 with the dipstick even less. Maybe some one has swapped the dipstick, I know 94.5 was a weird year, the truck has alot of idi parts
Old Sep 6, 2022 | 12:44 PM
knottyrope's Avatar
knottyrope
my 95 has IDI radiator and the dipstick looks like the one on the right but not sure if it was changed or not
Old Sep 7, 2022 | 08:52 AM
timlange's Avatar
timlange
I’m thinking it’s the factory dipstick but maybe the early years came with a different dipstick….. should I be adding more oil ? Especially is the oil capacity is the same throughout the years
Old Sep 7, 2022 | 12:42 PM
knottyrope's Avatar
knottyrope
maybe your 94.5 has had power issues from sucking air into LPOP?
if not then a quart or two more isnt going to hurt it.
Old Sep 7, 2022 | 01:06 PM
TheFecalFanatic's Avatar
TheFecalFanatic
I read somewhere that there were different dipsticks with correct/incorrect readings. I believe the late model dipstick is the one you want.
Old Sep 7, 2022 | 01:23 PM
timlange's Avatar
timlange
The 94.5 doesn’t feel like it down on power. I do have 160/30 in it though. I may change dipstick and start adding more oil. That engine has a bad aeration problem…. Maybe being low on oil does not help….. I know the early models had problems with the pick up tubes
Old Sep 7, 2022 | 07:32 PM
Talyn's Avatar
Talyn
94.5 had the incorrect dipstick in it.
It takes the same as all the other 7.3 powerstrokes.
Old Sep 7, 2022 | 07:33 PM
Talyn's Avatar
Talyn
So, I got this info on here years ago, but essentially, some of the early trucks came with a dipstick that had incorrect indications of oil level on it.
3.5 gallons is the correct amount of oil. Give or take a smidge.
Old Sep 7, 2022 | 07:39 PM
timlange's Avatar
timlange
Thank you I will change the dipstick!
Old Sep 7, 2022 | 07:51 PM
Talyn's Avatar
Talyn
One of the PO's of mine made a mark on it for the correct level.
I have the one you showing in my 94 with the lower line.
Whitey Ford
100
Aug 29, 2022 08:50 PM
Ltngdrvr
Aug 10, 2022 10:10 AM
Craig.Parks
Jan 23, 2013 01:15 PM
skullone
Jan 22, 2013 08:07 PM
IABill
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Feb 26, 2008 10:08 PM
