2016 Trans fluid change
Old Sep 5, 2022 | 08:07 AM
stvMo's Avatar
stvMo
Going to drop the pan at least 3 times to get rid of as much of the old fluid as possible then on the third change the filter. Do any of youz use Valvoline VI / Mercon LV full synthetic instead of Motorcraft Mercon LV ?
2016 F150 Lariat 5.0
Old Sep 5, 2022 | 11:15 AM
jimmy-six's Avatar
jimmy-six
My Ford like everyone I've ever owned would know when a non factory part was installed and reject it. Can't answer why but everyone knew when I did it.
Old Sep 6, 2022 | 09:07 AM
jake415's Avatar
jake415
I stick with OEM Mercon LV for many reasons. I found dropping the pan to be a mess though. I did that once to clean the magnets off and get the fluid level just right. Then I purchased a Mity-Vac to suction 3 quarts of fluid from the dipstick hole every other engine oil change. Then I invested a couple hundred in a B&M dipstick tube and add or subtract fluid through that with my Mity-Vac. Now it's a 15 min job without risk of being burned by hot cats!
https://www.skf.com/mityvac/products...cuators/mv7300
Old Sep 6, 2022 | 09:22 AM
scott91370's Avatar
scott91370
Look up Dorman 265-854 - Transmission Pan With Drain Plug
Keeps the mess to a minimum.
Old Sep 6, 2022 | 09:46 AM
stvMo's Avatar
stvMo
Nice... thnx
Old Sep 6, 2022 | 01:24 PM
jake415's Avatar
jake415
How is that less messy than suctioning the oil out and straight into a container?
Old Sep 6, 2022 | 03:51 PM
ojai150's Avatar
ojai150
Why not just unhook the trans cooler line and add fresh fluid until fresh starts coming out ?
Old Sep 6, 2022 | 06:06 PM
fordman19762003's Avatar
fordman19762003
My opinion is that if you need to change the fluid you also need to change the filter which requires the pan to be dropped.
Old Sep 7, 2022 | 10:04 AM
scott91370's Avatar
scott91370
Less messy that just dropping the pan and hoping it goes into the drain bucket.
I agree!
Old Sep 7, 2022 | 12:17 PM
stvMo's Avatar
stvMo
yep ..I agree
Old Sep 7, 2022 | 07:11 PM
jake415's Avatar
jake415
If you do some more research you will find that its not really a "filter" at all. Its more like a coarse screen. If its not clogged with chunks of metal, replacing it isn't really helping anything,,,
Old Sep 7, 2022 | 07:35 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If you do even more research you will find out that all of that changed in 2008. Now there is a real filter in the pan. It is no longer a screen, and it needs to be changed on a regular basis.
Old Sep 7, 2022 | 07:49 PM
jake415's Avatar
jake415
Ok, show us a link please, preferably with a pic of filter cut open. Everything I have read says otherwise. But now I won't know for sure until I cut one open...
Old Sep 7, 2022 | 08:47 PM
Mark Kovalsky
I don't have a link to share. I just know that when I was an automatic trans engineer at Ford the filters were changed in 2008 to real filters. You're welcome to believe or not believe what I said.
Old Sep 8, 2022 | 01:00 AM
85e150's Avatar
85e150
Looks like a popular item:
https://www.oreillyauto.com/detail/c...kit/mot0/ft188
