I just bought my first ford is a 1992 f250 7.3 idi automatic standard cab xlt 4x4, the dash bezel is destroyed but i cant find one for sale, does one from a 1994 f250 diesel fit? if not could someone let me know where i could find one? id like it new because this truck will be a show truck in time
Yes, 1992-1997 F-250 through F-Super diesel bezels are a direct fit. The plastic piece from any 1992-1997 F250 through F-Super, and a 1992-1996 F-150, will fit; but you may have to do some cutting and filing to make holes for the fuel tank switch and the diesel indicator cluster if it's not from a diesel w/ dual tanks application. Also be aware that the little "appliques" that have the turn signal indicators are different on SRS ("airbag") equipped trucks- these trucks had the alternator light inside the gauge cluster and used the corresponding hole in the bezel for an airbag warning. So if you use one in your truck, the alternator warning light will look like an orange dude with a mushroom in his lap, instead of a red battery shape.
