Hydroboost pedal swap question
Old Sep 4, 2022 | 08:47 PM
FordTruckfan89's Avatar
FordTruckfan89
Just recently did a hydroboost swap in my 89 f250.
I noticed this truck uses a vacuum dump valve for cruise control actuated by a white plastic part on the pedal. I modified a vacuum pedal by moving the pin, so I didn't have a parts truck to look at. Did the f superduties with cruise control use these as well? Also I noticed without the part on the pedal, the pedal seems to return much higher than the vacuum system. I attached a picture with the piece I'm talking about. Any help or guidance would be greatly appreciated
Old Sep 6, 2022 | 05:03 PM
FordTruckfan89
Bump. To be sure someone's run across this issue before on a 80-91 truck being swapped?
Old Sep 16, 2022 | 08:57 PM
FordTruckfan89
Couple things that may or may not be helpful to those in the future. The vacuum pedal works with hydroboost. Rotate the pushrod and the brake light switch 180 degrees. It'll line up well and work without binding.
I found I had an extremely low brake pedal. Found the reman booster I got has the incorrect length pushrod which is around 1" too short. Always measure. It should stick out about 1" from the mounting flange on the booster.
A company sells a cut to fit pushrod that fits all hydroboosts that will fix my issue.
Vacuum booster pushrod
Booster with incorrect pushrod
Ford booster with correct pushrod length
Old Sep 19, 2022 | 06:49 AM
Robfinger's Avatar
Robfinger
I think the F-Superduty also had the setup, just different part number for the plastic bit cause different location of pin? I'll be honest I did mine ages ago so I don't remember all the details anymore, and truck is currently an ocean away so can't just go and snap some pictures, but the cruise vacuum dump always worked right for me so I must have had all the proper parts there.
You want a crazy idea? Add another one of those valves to your clutch if you're running a bolt-action transmission, then you can do away with the troublesome electric switch on the clutch pushrod, which both allows you to use an adjustable pushrod with a heim joint and also makes it so the cruise reingages automatically after you've shifted gears without any input needed from you at the steering wheel. Also makes it so the truck will start without having to push the clutch in, which sounds kinda unsafe till you realize other manufacturers elsewhere in the world have been doing it for ages (my Pajero Mk2 for example has zero safeties on the clutch), but if you wanted to avoid that a GM brake switch from an 80s truck will do the job nicely.
Nathan Fuentes
13
Sep 18, 2022 04:29 AM
302flareside1992
13
Mar 31, 2016 02:21 PM
brokeasajoke
16
May 27, 2015 01:32 PM
ETKMS
6.4L Power Stroke Diesel
Aug 14, 2012 03:37 PM
ErrorS
1978 - 1996 Big Bronco
Dec 5, 2011 08:22 PM
