Elevated Oil and Coolant Temperatures
Old Sep 3, 2022 | 10:53 PM
Steamy Lou Stool's Avatar
Steamy Lou Stool
Ok, so long story short, I put new KDD heads, thermostat, radiator, oil cooler, etc.
Truck runs perfect except the coolant and oil temperatures are elevated now, about 204 coolant and 208 oil average, obviously running hotter than it should.
My question is what could be causing it, fully stuck or partially stuck thermostat, bad aftermarket radiator, fan clutch, etc?
Also, how would I go about testing and diagnosing the problem?
Info I can give as of now, the oil and coolant temperature averages above are flat at 65 mph, fan clutch I believe is working as I can see with forscan it climbing while in city traffic to compensate for the ac being on, and even on the interstate it the fan rpm’s when commanded fully on will basically match the engine rpm so I don’t believe the fan is the culprit, the radiator is an aluminum radiator from Amazon that had good reviews no more to say on it, the thermostat I am betting on, I have had multiple new ford thermostats come bad oem more than once. Also, heads are not leaking even after a wot test uphill while monitoring Egt, have been driving for 500+ miles.
Also, at an idle it will go down to a normal temperature 192 coolant and oil temp.
Any help is appreciated.
Old Sep 4, 2022 | 08:50 AM
TooManyToys.'s Avatar
TooManyToys.
You do have unique problems. I've never had to change a Ford thermostat because it failed (6.0 205k; Lincoln LS 165k, Edge 136k).
In your situation you can only A-B parts. Try a new thermostat (except from Mishimoto) and see if it changes.
I try to always get an OE assembly line radiators. I've never found aftermarket ones that cool as well.
Old Sep 4, 2022 | 03:29 PM
FiveOJester's Avatar
FiveOJester
What kdd heads are you running? Iron or aluminum?
What is your ambient air temp during these runs?
have you cleaned the stack up recently? Intercooler and AC condenser. They can get plugged up and restrict airflow to the radiator.
I would guess thermostat or a radiator with reduced surface area. Most of the aftermarket stuff I’ve seen has a lot less fins per inch than the stock one.
On my truck running down the highway when it’s over 100 outside with the AC running I can see the ECT creep up to 200. That’s a brand new stock radiator and thermostat.
Old Sep 4, 2022 | 10:56 PM
Steamy Lou Stool
Jester running the Iron heads, ambient was 106 degrees on a hot AZ day, new ac condenser, the intercooler is also clean, made sure when truck was apart, thermostat is from ford, Radiator like I said in my first post is aftermarket, but when matched up to the oem radiator it matches up surface area wise. I have an identical truck to compare to and it runs around 194 average for both ect and eot in the same conditions.
Old Sep 5, 2022 | 12:08 AM
TooManyToys.
Do both trucks have the same radiator?
The frontal surface area of a radiator is only one part of the ability. Tubes, tube size, fins per inch, rows, and the list goes on.
Old Sep 6, 2022 | 12:51 PM
FiveOJester
I would guess that is the cause of your elevated temps based on everything else looking good. Its likely got reduced fins per inch and smaller cores, etc. I wouldn't worry about 204F ECT, the truck actually runs better at high temp. The fan doesn't hit low speed until 208F.
I would be concerned when you are towing heavy loads you might get excessively high ECTs and corresponding EOT's. Definitely watch it if you do.
Old Sep 11, 2022 | 12:18 PM
Byrd.Dog's Avatar
Byrd.Dog
I have an aftermarket aluminum radiator on mine & the hottest it ever gets just cruising down the highway is 198 on a blistering summer day Usually ran 204-208 towing the 5th wheel.
Old Sep 11, 2022 | 10:05 PM
blicharski1989's Avatar
blicharski1989
It has been noted that the stock 6.0 radiator has more channels than almost all the aftermarket radiators. It’s a pretty efficient piece, some have slightly thicker cores. I would do a thermostat first and foremost cause it’s easy. Some folks have reported slightly higher running temperatures with the newer heads because they are thicker castings in some areas and they can limit some heat transfer. 200ECT is fine. 205ect wouldn’t really bother me either.
mine runs around 194-198f ect going down the highway at 75 with Ac on in ambient temps of 80-100F. It’ll hit 200-202 at a standstill like a traffic jam
Black diamond f550
6.7L Power Stroke Diesel
13
Jun 15, 2022 09:49 AM
can0fspam
Sep 13, 2021 12:32 AM
Ryan Schmidt
17
Aug 29, 2020 06:08 PM
dubnasty216
Dec 27, 2019 11:21 PM
LSO1123
Jul 7, 2015 11:49 AM
