Fuel Gauge Sending Unit ?
Old Sep 2, 2022 | 02:29 PM
blake in spokane's Avatar
blake in spokane
Is there a difference in ohm readings on a 53-55 & a 56 ?
Old Sep 2, 2022 | 07:13 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Those stock gauges do not operate on an ohms/resistance model, but the King-Seeley protocol. These sending units supply a full 6V through the heater wire in the gauge in the form of a square wave with the duration of the "on" being the variable determining the gauge reading. The longer the duration, the more fuel in the tank. It is this full 6v of current which heats the bi-metallic strip in the stock gauge that causes the gauge to read via a small gear train.
The way to test things is to test the gauge independently first with a D cell battery. It should swing to the half way point. If the gauge is good, the sending unit should be replaced (provided wiring and a good grounding has been established).
scottlathrop
Sep 28, 2016 06:33 AM
Hopsing69
Mar 16, 2014 09:38 PM
gusso
Electrical Systems/Wiring
Aug 8, 2007 10:33 AM
imlowr2
Jul 13, 2007 05:49 PM
HogTied
1983 - 2012 Ranger & B-Series
Oct 31, 2004 09:21 AM
