Fuel Pump Relay - 1992 e150
Old Aug 31, 2022 | 04:49 PM
gmd25m's Avatar
gmd25m
Does anyone have any instructions on troubleshooting the fuel pump relay from my 1992 e-150 ?
The relay seems to be a common one :
FOAB-14192-AA
Any help is appreciated.
Old Aug 31, 2022 | 10:13 PM
tabijan's Avatar
tabijan
That’s a common relay. Isn’t there another one in the van you can swap for testing?
Sixto
07 E350 5.4 183K miles
Old Sep 1, 2022 | 10:27 AM
manicmechanic007's Avatar
manicmechanic007
It's the green one and there is no other he can swap with on a 1992
They are cheap so you can just replace it , but I only saw a bad ones at the dealer in 25 years
Usually the ones that had fallen out of their holder, and were upside down getting wet
Those would have green corrosion that you could see underneath, and if you were to take the green cover off you would maybe see corroded points
You can jump that rellay and fire the pumps with a paper clip on that 92 from the self test connector
stevexcursion2005
Feb 20, 2022 09:50 AM
Oldblue1990
Jan 11, 2009 11:20 PM
jasonjason
Feb 18, 2008 05:19 PM
rluckey1
Feb 13, 2007 08:22 PM
