General Diesel Discussion
Additives Question
Old Aug 30, 2022 | 08:01 PM
personanongrada's Avatar
personanongrada
Additives Question
Am I correct in understanding that the one downside of additives (where you are attempting to add lubricity to protect the CP4) is that it may accelerate build up in the emissions systems? I'm sure that's over simplified. But if you could add enough lubricity through additives, then the CP4 would last longer. But the additives don't burn up as easily therefore you could have more EGR or other emissions related issues. Is that basically true, or not at all?
Old Sep 5, 2022 | 06:50 PM
Firesteel Ford's Avatar
Firesteel Ford
6th Gear
Is Seafoam good to use or not? I was running a 5.9L 12-valve cummins in my 1972 F250 high boy
Old Sep 7, 2022 | 05:46 PM
donovan's Avatar
donovan
BIG NO on the seafoam. It has alcohol. Don't be-leave everything you read on the bottle.
Bohen
6.7L Power Stroke Diesel
26
Apr 30, 2019 05:38 PM
Kylef25008
6.4L Power Stroke Diesel
Sep 29, 2017 09:31 PM
1983F1503004x4
Sep 28, 2011 05:48 PM
weekendwarriorfsw32
May 17, 2009 01:29 PM
pizalm
Exhaust Systems
Jun 11, 2004 03:35 PM
