Sponsored by: Real Truck
2016 6.7 Overheating
Old Aug 29, 2022 | 12:14 PM
bfd192's Avatar
bfd192
4wd Low
I have a 2016 F250 4x4 6.7; while pulling my 5th wheel, I got an overheating alert. The truck has 75,000 miles and has been serviced at the Ford dealer. The temperature would decrease to around the middle when I slowed down to under 50 mph. But If I tried to speed up, even on a flat area, the temperature would go up past 3/4. I would let off before I got the "H." I have seen many posts about this issue and the higher temps being regular. It has never done this with this trailer, not the overheating alarm or higher temps. I have read about the coolant needing to be changed out because it can lose its "wet" ability, whatever that is. All fluid levels are complete, and the fan is working. And my warranty just expired at 75,000, and I am at 75,140.
Old Aug 29, 2022 | 12:31 PM
redford's Avatar
redford
FTE Leadership Emeritus
Is your cooling fan kicking in?
Old Aug 29, 2022 | 12:39 PM
StngStr's Avatar
StngStr
140 miles past warranty, I'd still take it in and see if they'll warranty it.
Old Aug 29, 2022 | 12:47 PM
bfd192's Avatar
bfd192
4wd Low
Yes. Everything seems to be working fine. Truck works perfect when not pulling.
Old Aug 29, 2022 | 12:55 PM
redford's Avatar
redford
But did you hear the roaring jet noise of your cooling fan when your truck got hot?
Old Aug 29, 2022 | 02:22 PM
bfd192's Avatar
bfd192
4wd Low
I think but would need to check that
Old Aug 31, 2022 | 02:03 PM
omanolo's Avatar
omanolo
Do you have a transmission temperature gauge? What color is your transmission fluid? Red or brown?
Old Aug 31, 2022 | 02:11 PM
'65Ford's Avatar
'65Ford
Look into your cooling stack for leaves, bugs, grass, dust, etc. Back wash with a garden house if needed.
Fosters
6.7L Power Stroke Diesel
19
Sep 9, 2022 11:54 AM
WhiteBeast-05-powers
Mar 12, 2016 08:13 PM
ROBBINthaHOOD
Sep 11, 2013 01:05 AM
mblanken881
Mar 23, 2011 08:56 PM
maint_manager
Jul 13, 2005 06:35 PM
