water separator assembly replacement
Old Aug 27, 2023 | 02:13 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by 406f150
Does anyone know if the updated housings help with the issue of fuel continuing to drain on the 2017s, or is that related to something different?
2017 is the only year called out in the manual as possibly requiring the fuel line to be disconnected to avoid siphoning. I never knew if that was because of a different housing, or some differences up stream. There have been posts from owners of '18 and up still having issues with siphoning. So apparently whatever the cause of the siphoning is, it wasn't completely fixed after 2017.
Old Aug 29, 2023 | 02:44 PM
rufushusky's Avatar
rufushusky
IIRC if you break the seal on the housing it will stop the siphoning.
G-one-K
Jan 27, 2022 10:04 PM
jfralph
6.7L Power Stroke Diesel
34
Sep 30, 2020 03:24 PM
JOSHfrompa
20
Aug 15, 2018 06:00 AM
Mitragorz
Jun 26, 2018 10:45 PM
garmford
22
Jul 24, 2016 05:46 PM
