Sponsored by: Real Truck
01' Power Door Locks
Old Aug 28, 2022 | 11:59 AM
Big Green Booger's Avatar
Big Green Booger
Did a quick search but did not see anything. The door locks on my 01' do not always work with the key fob. I can see them move when I hit the button but they do not always fully lock/unlock. Was thinking I need to pull the door panels and lube things but wanted to check in and see if someone else fixed this issue a different way.
Old Aug 28, 2022 | 12:21 PM
projectSHO89's Avatar
projectSHO89
More likely than not, the actuators are failing.
Old Aug 28, 2022 | 08:03 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
I believe, by the sound of the description your actuators done. About a year ago I changed out all four on my truck, not a hard job.
Make sure your windows are full up when you pull the panels off. I also if I remember correctly think you will need a 10mm socket, about 5 inch extension, and a (maybe) 25 torque bit??? Instructions can be found on this site as that is where I got it from or YouTube. The panels take as long to get on and off as the actuator replacement.
Old Aug 29, 2022 | 11:01 AM
Big Green Booger
Great, thank you guys!
Old Aug 29, 2022 | 04:07 PM
AACoPD05's Avatar
AACoPD05
Same opinion, actuators. I also did all 4 at the same time, everything works as advertised now.
gjnicholas
1978 - 1996 Big Bronco
May 7, 2010 08:53 PM
rosey123
Feb 1, 2010 07:23 PM
totavikid
Sep 1, 2004 11:52 PM
laha
Jan 28, 2003 05:00 PM
