2001 Power Door Locks
Old Aug 28, 2022 | 11:37 AM
Big Green Booger's Avatar
Big Green Booger
Did a quick thread search and did not see any about power door locks. My 01' F250 door locks do not always work with the key fob. I see them try but they don't always engage, seems to be more often when the climate is cooler, I think. Has anyone had the issue and what was the fix. I was thinking of pulling the door panels and lubing things up but before I start in I thought I would see what the experts say.
Old Aug 28, 2022 | 11:39 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
You're in the wrong section, this is 17+ forum.
Old Aug 28, 2022 | 11:55 AM
Big Green Booger
oops, thanks
Old Aug 28, 2022 | 02:16 PM
Lariat Driver's Avatar
Lariat Driver
Veteran: Navy
I had that same problem on a 2001 Other Brand truck. I tracked when the locks worked and didn't work for about two weeks and finally figured out it was the battery. My problem also seemed worse when it was cooler, like first thing in the morning. The battery was strong enough to start and run everything without showing any signs of failure, but the power locks weren't getting enough juice for them to work consistently. It was really weird but as soon as I replaced the battery a few months later the door lock problem was cured.
Old Aug 28, 2022 | 03:48 PM
Sport45's Avatar
Sport45
On my ‘00 F-250 I fixed the inop power locks by wrapping the internal flat resistor with some thin foil. IIRC the foil came from chewing gum wrappers.
Old Aug 28, 2022 | 03:57 PM
jade97's Avatar
jade97
Or search for the $0.01 mod.....I used it in the driver's side rear door on my 2002 F250 CC many, many years ago.
Old Aug 28, 2022 | 07:21 PM
Sport45's Avatar
Sport45
That’s it! But I couldn’t find it with a quick search.
Tpap595
2009 - 2014 F150
Jun 30, 2017 03:05 PM
jmuenchow
Jun 29, 2015 04:54 PM
totavikid
Sep 1, 2004 11:52 PM
toolman11m
1983 - 2012 Ranger & B-Series
Apr 19, 2003 08:00 PM
laha
Jan 28, 2003 05:00 PM
