7.3 injectors not working.
Old Aug 26, 2022 | 10:54 AM
Dan V's Avatar
Dan V
I'd try to get a real HPOP pressure reading while cranking.
Old Aug 26, 2022 | 09:28 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Fuel pressure is always over looked.
Old Aug 26, 2022 | 10:12 PM
2001F350dualwheel's Avatar
2001F350dualwheel
Originally Posted by Muteme87
filter is good I even pulled it for a sec to see. And ya I disabled the dummy no fuel filter fuel block. When cracking I should hear the injectors pretty good right?
you’re not getting fuel. Check oil level and please stop using starting fluid. Low oil will keep the truck from starting. Is the engine oil topped off to the full mark? If no top it off then try starting.
If it’s full but still won’t start with the basics.
1. do you have enough fuel in the tank. Forget the gauge it could be stuck or broken or givecerroneous racing. Get under there bang on the tank.
are you getting power to the fuel pump. It’s on the inside of the frame rail under driver seat. Hen you turn the key on are you getting power to the pump? Yes? No.
if no then check the fuses for the fuel pump and the relay
if yes
is the fuel pump pressurizing when you turn on the key.
yes? No?
if yes …is the fuel bowl at the engine filling up with fuel
yes? No?
if yes
are you using the correct filter. I know you said you got rid of the plastic one way valve. Are you sure you removed it correctly and completely and aren’t blocking the fuel delivery at that point. Did you buy pass the fuel heater correctly.
if the bowl is filling up is the fuel coming out in the lines feeding the heads
yes ? No?
if no your issue is at the fuel bowl
your truck cranks, the injectors pulse. You’re missing fuel. At some point in the line the fuel isn’t entering the injectors.
Old Aug 27, 2022 | 01:56 PM
Muteme87's Avatar
Muteme87
if yes
yes? No?
yes? No?
if yes
yes ? No?
yes the oil is full. the fuel bowl fills fast it has 1/2 tank. I need to check my fuel pressure. I'm going to do that now.
I won't leave this thread unfinished i hate when ppl do that. I only have a couple days a week I can mess with it I'm not ignoring anyone. Thanks to everyone that is helping.
Old Aug 27, 2022 | 02:05 PM
2001F350dualwheel
Then if that’s the case your issue is between the bowl and injectors. What was changed, done or not done? The one way valve push down valve and the heater element..correct? Make sure that’s either dine correctly or reinstall the parts or replace as needed.
you can crack the fuel line coming out from the bowl feeding the injectors and see if fuel is pumping out. If it is the problem is at the injectors. Either they aren’t getting a pulse or the harness is broken somewhere.
look on the driver side where the harness lays against the valve cover. Look at the underneath section of the harness Vibration rubs the harness and the wiring grounds out.
Muteme87
64
Sep 23, 2022 08:42 PM
kdbou
Mar 5, 2021 02:59 AM
yzf450motoxrider
20
Apr 28, 2019 05:09 AM
briancbk
Sep 12, 2011 07:05 AM
BamaDiesel77
May 5, 2007 07:09 PM
