need help with my 86 e 150.
Old Nov 11, 2003 | 06:39 AM
1allen's Avatar
1allen
I am haveing fuel problems with my 86 E 150 no fuel to the injector ireplaced the fuel pump but still no fuel i have also checked to see if any power was getting to the pump and it was not could someone please give me some idea on what i am over looking
Old Nov 19, 2003 | 12:29 AM
86F150 4X4 351F.I.'s Avatar
86F150 4X4 351F.I.
Make sure that your fuel filter is not plugged,I would also check if there is even gas pumping from the tank,(if none possible fuel pickup tube is broke or the fuel tank selector is not switching)make sure you can hear the fuel pump cycle when you turn the key on.
Old Nov 19, 2003 | 02:03 AM
vanmancan's Avatar
vanmancan
Wink
Check to see if there is power delivered to and from the selenoids that energize the fuel pumps. There are two of those located on the passenger side side-wall as you open the hood.
If there is power to the selenoids and no power out from them then replace the faulty one. They can corrode and /or wear out.
If there is no power to the selenoids, check for a broken supply wire. In mine it was a broken wire that got jammed (while still in the harness) underneeth the inside engine cover and some bracket for the injectors.
I found the broken wire after I had taken the gas tank out looking for a broken fuel pump which of course was working just fine.
Best of luck!
Old Nov 25, 2003 | 05:49 PM
The Weezle's Avatar
The Weezle
Check the roll over switch drivers side near the E brake
de pressurizing the fuel system will cause them to trip
Old Nov 25, 2003 | 10:02 PM
locknkey's Avatar
locknkey
1allen
Quote:"fuel problems with my 86 E 150 no fuel to the injector "
Is that with one injector or all of em?
Old Aug 9, 2004 | 04:38 AM
Cracker289's Avatar
Cracker289
Listen to "The Weezle" above, check/reset the impact switch or whatever it's called.
Old Aug 9, 2004 | 06:12 AM
locknkey's Avatar
locknkey
Do you think he is stll waiting for a answer? He posted in 2003.
Old Aug 9, 2004 | 06:24 AM
1allen's Avatar
1allen
Thanks Guys it was the impact switch,I do,nt know what could have coused it to shut down but no matter it is fixed and i must say THANKS very much for the great help from you ALL.
Old Aug 9, 2004 | 10:20 PM
Cracker289's Avatar
Cracker289
Locknkey, you're right, I didn't even notice that. I was reading thru posts last night and did not even pay attention to how old the thread was. I got egg on my face.
Old Aug 10, 2004 | 01:14 AM
1allen's Avatar
1allen
Thanks anyway Cracker289 it,s good to know you were willing to help.
Old Aug 10, 2004 | 06:26 AM
locknkey's Avatar
locknkey
Hey Cracker289... its easy to mess up around here, I done it too...only they didn't reply...1Allen did, it shows that he's still a FORD man.
